Gravity: URM09 Ultrasonic Distance Sensor (2~500cm, Trig)
$7.90
SKU: SEN0388
  • $7.70 3+ items
  • $7.50 5+ items
  • $7.30 10+ items
High-performance ultrasonic sensor with 2-500cm range, accuracy of 1%, and single I/O port operation. Compatible with 3.3V/5V controllers.
This is a non-contact ultrasonic ranging sensor of high-performance from URM09 series, employing standard PH2.0-3P Gravity vertical interface. It provides an accuracy of 1% within an effective measuring range of 2~500cm(test on a flat wall). Similar to SR04 ultrasonic ranging modules in principle and using method, the ranging function of this sensor is triggered by high/low-level output from the I/O ports of a host, and then the sensor converts ultrasonic flight time into a high pulse to output. The difference is that this sensor multiplexes input and output signals onto one signal port, which allows users to easily use the sensor for distance measurement only by one I/O port of a controller. Meanwhile, the adoption of advanced hardware and software design ensures excellent and reliable measuring performance. The module works well with 3.3V/5V controllers like Arduino, Raspberry Pi, etc.
URM09 Beam Angle
URM09 Beam Angle
If you need want to learn more about ultrasonic sensors, please click here to check DFRobot Ultrasonic Sensor Selection Guide.
  • Operating Voltage: 3.3~5.5V DC
  • Max Instantaneous Working Current: <20mA
  • Operating Temperature Range: -10℃~+70℃
  • Effective Ranging Range: 2cm~500cm
  • Resolution: 1cm
  • Accuracy: 1%
  • Acoustic Frequency: 40±2KHz
  • Ranging Frequency: 25Hz Max
  • Dimension: 47×22mm/1.85×0.87”
  • URM09 Ultrasonic Sensor(Gravity Trig) x1
  • PH2.0-3P Sensor Connector x1
    DFRobot URM Ultrasonic Distance Sensor Selection Guide
    Blog DFRobot URM Ultrasonic Distance Sensor Selection Guide
    Apr 08, 2020
    How Accurate are mmWave Sensors?
    Blog How Accurate are mmWave Sensors?
    May 04, 2023
    Ultrasonic Sensor Review: Comparing DFRobot URM09, HC-SR04, Devantech SRF02 & Maxbotix MB1040
    Blog Ultrasonic Sensor Review: Comparing DFRobot URM09, HC-SR04, Devantech SRF02 & Maxbotix MB1040
    Nov 23, 2023
    DFRobot URM Ultrasonic Sensors:  High-Performance and Diverse Selection
    Blog DFRobot URM Ultrasonic Sensors: High-Performance and Diverse Selection
    Aug 15, 2023
    Out Of Stock
