FireBeetle 2 ESP32-E IoT Microcontroller (32M / 512KB, Supports Wi-Fi & Bluetooth)
$8.90
SKU: DFR0654
  • $8.60 3+ items
  • $8.50 5+ items
  • $8.30 10+ items
The ESP32-E controller board supports WiFi, Bluetooth, Arduino, and will soon support Scratch and MicroPython. It's ideal for IoT applications.
FireBeetle 2 ESP32-E, specially designed for IoT, is an ESP-WROOM-32E-based main controller board with dual-core chips.
It supports WiFi and Bluetooth dual-mode communication and features a small size, ultra-low power consumption, on-board charging circuit, and easy-to-use interface, which can be conveniently used for smart home IoT, industrial IoT applications, and wearable devices, and so on. You can easily create your own IoT smart home system when connecting it with an IoT platform like IFTTT.
FireBeetle 2 ESP32-E supports Arduino programming and will support Scratch graphical programming and MicroPython programming very soon. We provide you with detailed online tutorials and application cases, and there are thousands of sensors with welding-free Gravity interfaces and actuators to help you get started easily. Besides, the stamp hole design makes it able to be easily embedded in your PCB, greatly saving your costs and time to build and test a prototype.
Note: FireBeetle 2 and FireBeetle pins and sizes are not compatible, and neither are the expansion boards.
FireBeetle 2 Board ESP32-E Board Overview (Arduino Compatible)
Figure 1. Board Overview
FireBeetle 2 Board ESP32-E IoT Microcontroller Pinout
Figure 2. Pinout
  • ESP32 dual-core low-power main controller with power consumption as low as 2mA
  • WiFi+Bluetooth 4.0 Dual-mode Module
  • GDI Display Port, easy to connect
  • Onboard Charging Circuit and PH2.0 lithium Battery Interface
    Power Parameters - Input Voltage
  • USB-C Port: 5V DC
  • PH2.0 Connector: 3.7~4.2V Li-ion
  • VCC Pin: 5V DC
  • MCU Parameters
  • Processor: Xtensa Dual-Core 32-bit LX6 Microprocessor
  • Clock Speed: 240 MHz
  • SRAM: 520 KB
  • ROM: 448 KB
  • Flash Memory: 4 MB
  • Wireless Parameters—Wi-Fi Protocol:
  • IEEE 802.11 b/g/n (Data rate up to 150 Mbps in 802.11n mode)
  • Supports A-MPDU and A-MSDU aggregation
  • Supports 0.4 μs guard interval
  • Operating Channel Center Frequency Range: 2412~2484 MHz
  • Wireless Parameters—Bluetooth Protocol:
  • Bluetooth V4.2 BR/EDR and Bluetooth LE standards
  • Bluetooth CVSD and SBC audio
  • Bluetooth Frequency Range: 2402~2480 MHz
  • Peripheral Parameters
  • Digital Pins × 18: IO0, IO1, IO2, IO3, IO4, IO12, IO13, IO14, IO15, IO16, IO17, IO18, IO19, IO21, IO22, IO23, IO25, IO26
  • Analog Pins × 11: IO0, IO2, IO4, IO12, IO13, IO14, IO15, IO25, IO26, I34, I35
  • UART Interfaces: × 2
  • SPI Interface: × 1
  • I2C Interface: × 1
  • I2S Interface: × 1
  • DAC Interfaces: × 2
  • Touch Interfaces: × 7
  • LED PWM Channels: × 16
  • RGB_LED: WS2812
  • Display Interface: GDI
  • Other Parameters
  • Module Size: 25.4mm × 60mm
  • Mounting hole size: hole diameter 2.0mm
  • Weight: 23g
  • FireBeetle 2 Board ESP32-E x1
  • 18pin-2.54mm Pitch Pin x1
  • 18pin-2.54mm Pitch Pin Female x1
  • 14pin-2.54mm Pitch Pin x1
  • 14pin-2.54mm Pitch Pin Female x1
    FireBeetle V1 vs V2 (ESP32/ESP8266/Arduino) Development Board Selection Guide
    Blog FireBeetle V1 vs V2 (ESP32/ESP8266/Arduino) Development Board Selection Guide
    Jun 08, 2025
    ESP32 cpplinq Tutorials Menu
    Blog ESP32 cpplinq Tutorials Menu
    Apr 25, 2021
    Blog ESP32 HTTP server Tutorials Menu
    Apr 25, 2021
    ESP32 Soft AP Tutorials Menu
    Blog ESP32 Soft AP Tutorials Menu
    Apr 25, 2021
    ESP32 MicroPython Tutorials Menu
    Blog ESP32 MicroPython Tutorials Menu
    Apr 01, 2021
    ESP32 Arduino Tutorials Menu
    Blog ESP32 Arduino Tutorials Menu
    Apr 20, 2021
    Matthew.Kinney Mar 26, 2026
    Love these mCU's. The best part is the GDI interface for the displays they offer. Also the price is really good when you compare it to other companies like sparkfun. The GDI is great for prototyping so you dont have to run wires or solder anything.
    KOUBELAN RICHARD.AKPAGNI Nov 07, 2025
    Excellent IoT board for both beginners and professionals. The FireBeetle 2 ESP32-E is compact, stable, and very power-efficient. The 32 MB flash and 512 KB RAM make it ideal for complex IoT or AIoT projects. Wi-Fi and Bluetooth connectivity work flawlessly, and it integrates perfectly with Arduino IDE or PlatformIO. I used it in a smart sensor project with multiple peripherals, and it performed very reliably. Highly recommended for anyone looking for a solid ESP32 development board
    Alexandre.Charles Jan 04, 2026
    Exactement la carte que je recherchais pour corrigé mes problèmes de deep sleep !
