FireBeetle 2 ESP32-E, specially designed for IoT, is an ESP-WROOM-32E-based main controller board with dual-core chips.
It supports WiFi and Bluetooth dual-mode communication and features a small size, ultra-low power consumption, on-board charging circuit, and easy-to-use interface, which can be conveniently used for smart home IoT, industrial IoT applications, and wearable devices, and so on. You can easily create your own IoT smart home system when connecting it with an IoT platform like IFTTT.
FireBeetle 2 ESP32-E supports Arduino programming and will support Scratch graphical programming and MicroPython programming very soon. We provide you with detailed online tutorials and application cases, and there are thousands of sensors with welding-free Gravity interfaces and actuators to help you get started easily. Besides, the stamp hole design makes it able to be easily embedded in your PCB, greatly saving your costs and time to build and test a prototype.
Note: FireBeetle 2 and FireBeetle pins and sizes are not compatible, and neither are the expansion boards.
Figure 2. Pinout
Power Parameters - Input Voltage
MCU Parameters
Wireless Parameters—Wi-Fi Protocol:
Wireless Parameters—Bluetooth Protocol:
Peripheral Parameters
Other Parameters
Mar 26, 2026
Love these mCU's. The best part is the GDI interface for the displays they offer. Also the price is really good when you compare it to other companies like sparkfun. The GDI is great for prototyping so you dont have to run wires or solder anything.
Nov 07, 2025
Excellent IoT board for both beginners and professionals. The FireBeetle 2 ESP32-E is compact, stable, and very power-efficient. The 32 MB flash and 512 KB RAM make it ideal for complex IoT or AIoT projects. Wi-Fi and Bluetooth connectivity work flawlessly, and it integrates perfectly with Arduino IDE or PlatformIO. I used it in a smart sensor project with multiple peripherals, and it performed very reliably. Highly recommended for anyone looking for a solid ESP32 development board
Jan 04, 2026
Exactement la carte que je recherchais pour corrigé mes problèmes de deep sleep !
