Mini Digital Bluetooth Amplifier-50W*2
$12.90
SKU: DFR0799
  • $12.60 3+ items
  • $12.20 5+ items
  • $11.90 10+ items
Mini Bluetooth amplifier offers 50W output, adjustable volume, Bluetooth 5.0, dual-channel, and protection features. Compatible with 30W-200W speakers.
This mini Bluetooth Amplifier can be connected to your mobile phone, Raspberry Pi, and other main-boards with Bluetooth to DIY your unique speaker! With standard audio quality, the cost-effective amplifier offers 50W output power, volume adjustable knob, Bluetooth 5.0 input, and dual-channel output. It can be powered at DC 5~24V, and compatible with 4-8Ω, 30W-200W passive speakers.
The Bluetooth Amplifier comes with bottom/top protective covers and supports overheat and short-circuit protection.
Operation Instruction
Connect the board with a speaker, power it on. Rotate the volume knob then the indicator LED lights up. Turn on the Bluetooth of your phone or Raspberry Pi, the “BT-WUZHI” will be searched, and then click to connect it. It connects successfully with a ding-dong tone, and now it can play music. The Bluetooth will be connected automatically when the module is powered on next time.
Note
The board will output adequate power only when the audio input and power source voltage/current are sufficient. The higher the power supply voltage, the larger the output power. Besides that, speaker impedance also changes the amplifier board power output. Please note that in the case of enough voltage and current, the larger the speaker impedance in ohms, the smaller the output power.
  • Power Supply: 5-24V
  • Input: Bluetooth 5.0
  • Audio Quality: standard
  • Output Power: 50W*2
  • Compatible Speakers: 30W-200W, 4Ω-8Ω
  • Channel: left/right (stereo)
  • Bluetooth Transmission Distance: 15m(Without any obstacle)
  • Protection: overheat, short-circuit
  • Power Voltage:
                  12V--8Ω Speaker/12W(left)+12W(right), 4Ω Speaker/20W+20W
                  15V----8Ω/18W+18W,4Ω/>30W+30W
                  19V----8Ω/32W+32W,4Ω/>45W+45W
                  24V----8Ω/38W+38W,4Ω/>50W+50W
  • Mini Digital Bluetooth Amplifier-50W*2 x1
  • Acrylic Protective Case x2
  • Screwdriver x1
  • 20cm Power Wire x1
  • Knob x1
  • Accessories Package x1
  • Heat Sink x1
    Bluetooth Amplifier Board Selection Guide
    Blog Bluetooth Amplifier Board Selection Guide
    Feb 07, 2021
    Only 6 Left
