Gravity: SGP40 Air Quality Sensor
$13.90
SKU: SEN0394
  • $13.60 3+ items
  • $13.30 5+ items
  • $12.90 10+ items
This air quality sensor features low power usage, fast response, and small size. Ideal for indoor use, with VOC index indicating air quality directly.
The SGP40 Air Quality sensor adopts the new SGP40 digital VOC sensor chip launched by the well-known Sensirion. Based on the Sensirion’s CMOSens® technology, the SGP40 offers a complete sensor system on a single chip, a temperature-controlled micro-hotplate and a humidity-compensated indoor air quality signal. In combination with Sensirion’s powerful VOC algorithm, the sensor signal can be directly used to evaluate indoor air quality. It features low power(2.6mA), fast response(2s) and small size. The data from the sensor can be directly used to evaluate air quality without calibration.
Integrated with an easy-to-connect Gravity interface, this Gravity SGP40 Air Quality sensor is very suitable for indoor projects that will be used for a long time, such as refitting air purifiers, kitchen hoods, etc. Besides, we provide you with C and Python libraries for use with different main-controllers.
Note: VOC index is obtained by converting the detected ethanol equivalent in air.
  • Ultra-low power consumption(2.6mA)
  • Built-in temperature and humidity compensation, no need to calibrate
  • VOC index for direct air quality indication
  • Air Purifiers
  • Kitchen Hoods
  • Demand-controlled Ventilation
  • Thermostats
  • Indoor Air Quality Monitoring
  • Power Supply: 3.3V~5V
  • Operating Current: 2.6mA
  • Preheat Time: 10S
  • Response Time: 2S
  • Communication: I2C
  • I2C Address: 0x59
  • Operating Temperature Range: -10℃~50℃
  • Storage Temperature Range: 5℃~30℃
  • Operating Humidity Range: 0%RH~90%RH
  • VOC Index: 0-500
  • Measuring Range: 0-1000ppm(Ethanol Equivalent)
  • Dimension: 20*22mm/ 0.79*0.87”
  • Gravity: SGP40 Air Quality Sensor x1
  • Gravity-4P I2C/UART Sensor Cable x1
    PET POT
    Projects PET POT
    Mukesh Sankhla
    Sep 09, 2023
    Michael.Samyn Mar 09, 2026
    It works fine. Easy to connect and to import the library. The product is of good quality
    hwang.yuns Oct 17, 2025
    great! The sensor works well. It's a good choice for me.
