Need high-speed, low-power Wi-Fi for IoT gateways, touch interfaces, or multimedia projects? The ESP32-S2-WROVER delivers 240MHz performance, 4MB flash, and 2MB PSRAM—ideal for demanding embedded applications.
Ultra-Fast 240MHz Xtensa LX7 Core
Built with a single-core 32-bit LX7 CPU, enabling real-time processing for audio, video, and sensor applications.
Enhanced Memory (4MB Flash + 2MB PSRAM)
Offers ample storage and fast data buffering, perfect for complex firmware and multimedia streaming.
Rich Peripheral Support (USB OTG, Touch Sensors, PWM)
Includes 43 GPIOs, USB OTG, touch sensors, and LCD/camera interfaces for versatile IoT development.
Low-Power Wi-Fi for Battery-Powered Devices
Supports 802.11 b/g/n (150Mbps) with dynamic voltage scaling for energy-efficient wireless connectivity.
Note: This module is recommended for developers currently. The peripheral circuit needs to be soldered when using it, and few peripheral interfaces may not perform the full functionality of the sample code. There are still bugs that have to be found and fixed.
IoT gateways
Audio processing
Video streaming
Touch interface projects
MCU
Built-in ESP32-S2 chip, Xtensa® single-core 32bit LX7 microcontroller, up to 240MHz
Support multiple low-power modes: fine-grained clock gating, dynamic voltage and frequency scaling
Security: eFuse, Secure Boot, Flash Encryption, Digital Signature, Integrated AES, SHA and RSA algorithms
128 KB ROM
320 KB SRAM
16 KB RTC SRAM
WiFi
802.11 b/g/n
Data rate up to 150Mbps
TX/RX A-MPDU, RX A-MSDU
0.4µs guard interval
Center frequency range of operating channel: 2412 ~ 2484 MHz
Hardware
Port: GPIO, SPI, UART, I2C, I2S, LCD interface, Camera interface, IR, pulse counter, LED, PWM, USB1.1, ADC, DAC, capacitive touch sensor, temperature sensor
40 MHz Oscillator
4 MB SPI Flash
2 MB PSRAM
Operating Voltage/Power Voltage: 3.0 ~ 3.6 V
Suggested Operating Temperature: –40 ~ 85 °C
Package Size: (18 x 31 x 3.3) mm
Certification
RoHS/REACH
RF Certification: FCC/CE-RED/SRRC
Test
HTOL/HTSL/uHAST/TCT/ESD
ESP32-S2-WROVER Wi-Fi Module (PCB antenna) x1
