ESP32-S2-WROVER Wi-Fi Module – 4MB Flash, 2MB PSRAM, 240MHz (PCB Antenna)
$3.50
SKU: DFR0743-WROVER
WiFi MCU module with 42 pins, 4MB flash, 2MB PSRAM, USB OTG. Ideal for audio/video processing. Requires soldering, developer use recommended.
Purchase this product and earn 35 reward points, which are tied to VIP membership program. Learn More >
Need high-speed, low-power Wi-Fi for IoT gateways, touch interfaces, or multimedia projects? The ESP32-S2-WROVER delivers 240MHz performance, 4MB flash, and 2MB PSRAM—ideal for demanding embedded applications.
Ultra-Fast 240MHz Xtensa LX7 Core
Built with a single-core 32-bit LX7 CPU, enabling real-time processing for audio, video, and sensor applications.
Enhanced Memory (4MB Flash + 2MB PSRAM)
Offers ample storage and fast data buffering, perfect for complex firmware and multimedia streaming.
Rich Peripheral Support (USB OTG, Touch Sensors, PWM)
Includes 43 GPIOs, USB OTG, touch sensors, and LCD/camera interfaces for versatile IoT development.
Low-Power Wi-Fi for Battery-Powered Devices
Supports 802.11 b/g/n (150Mbps) with dynamic voltage scaling for energy-efficient wireless connectivity.
Note: This module is recommended for developers currently. The peripheral circuit needs to be soldered when using it, and few peripheral interfaces may not perform the full functionality of the sample code. There are still bugs that have to be found and fixed.
  • IoT gateways
  • Audio processing
  • Video streaming
  • Touch interface projects
    MCU
  • Built-in ESP32-S2 chip, Xtensa® single-core 32bit LX7 microcontroller, up to 240MHz
  • Support multiple low-power modes: fine-grained clock gating, dynamic voltage and frequency scaling
  • Security: eFuse, Secure Boot, Flash Encryption, Digital Signature, Integrated AES, SHA and RSA algorithms
  • 128 KB ROM
  • 320 KB SRAM
  • 16 KB RTC SRAM
  • WiFi
  • 802.11 b/g/n
  • Data rate up to 150Mbps
  • TX/RX A-MPDU, RX A-MSDU
  • 0.4µs guard interval
  • Center frequency range of operating channel: 2412 ~ 2484 MHz
  • Hardware
  • Port: GPIO, SPI, UART, I2C, I2S, LCD interface, Camera interface, IR, pulse counter, LED, PWM, USB1.1, ADC, DAC, capacitive touch sensor, temperature sensor
  • 40 MHz Oscillator
  • 4 MB SPI Flash
  • 2 MB PSRAM
  • Operating Voltage/Power Voltage: 3.0 ~ 3.6 V
  • Suggested Operating Temperature: –40 ~ 85 °C
  • Package Size: (18 x 31 x 3.3) mm
  • Certification
  • RoHS/REACH
  • RF Certification: FCC/CE-RED/SRRC
  • Test
  • HTOL/HTSL/uHAST/TCT/ESD
  • ESP32-S2-WROVER Wi-Fi Module (PCB antenna) x1
  • Only 19 Left
