Fermion: VL53L3CX ToF Distance Ranging Sensor (25-3000mm) (Breakout)
$8.90
SKU: SEN0378
  • $8.70 3+ items
  • $8.60 5+ items
  • $8.30 10+ items
The VL53L3CX sensor offers 25-3000mm range, multi-target detection, smudge correction, glass cross-talk immunity, and operates at 3.3V~5V.
The VL53L3CX is the latest Time-of-Flight (ToF) product from STMicroelectronics and embeds ST’s third-generation FlightSense technology. With the improved detection accuracy, the sensor features a 25~3000mm sensing range, automatic smudge correction, and glass cross-talk immunity. With special algorithms and ingenious module construction, the VL53L3CX is also able to detect different objects within the field of view (FoV) with depth understanding.
Note 1: The product has only been verified on M0 and ESP32 due to the large size of its algorithm files.
Note 2: Multi-target distance measurement can only be triggered under certain conditions. Please refer to their official Web for more details.
Fermion:VL53L3CX ToF Distance Ranging Sensor (Breakout)
Board-Overview
Note3: The detection range of 25mm-3000mm comes from the datasheet of STMicroelectronics Rev 2. The actual sensing distance varies with the environment. For measurement environment information, please refer to document AN5561 at the end of Wiki.
  • High accuracy distance measurement
  • Long-distance and accurate ranging up to 300 cm
  • Typical full FoV 25°
  • Multi-target distance ranging
  • Immune to glass cross-talk
  • Smudge compensation function
  • Power Supply: 3.3V~5V
  • Operating Current: <20mA
  • Detection Range: 25-3000mm
  • Emitter: 940nm invisible laser(VCSEL)
  • FOV: 25°
  • I2C Address: 0x29
  • Operating Temperature Range: -20℃~85℃
  • Dimension: 18x15mm/0.71x0.59"
  • Fermion:VL53L3CX ToF Distance Ranging Sensor(Breakout) x1
  • 2.54-6P Black Single Row Connector x1
  • FAQ
