Ring Inductive Proximity Sensor (6mm Hole Diameter) is designed for reliable detection of metal objects passing through or entering a sensing ring. Powered by a wide 6–36V supply, this industrial inductive detection module delivers stable NPN normally‑open output suitable for automation control, equipment monitoring, and embedded electronics projects. Fast response speed below 1ms enables accurate recognition of rapidly moving small metal components. A durable brass nickel‑plated flame‑retardant enclosure combined with IP66 protection ensures dependable performance in demanding factory environments as well as outdoor installations.
Figure: Ring Inductive Proximity Sensor
High‑Speed Metal Detection
This inductive ring detector identifies metallic objects traveling through the sensing aperture with a response time of less than 1ms. Such rapid switching capability enables reliable monitoring of high‑speed production lines where small components such as screws, washers, or nuts pass quickly through detection points. Accurate switching performance and a 300Hz frequency allow the sensing unit to maintain stable detection even in dynamic mechanical systems.
Adjustable Sensitivity with Visual Status Indicator
An integrated sensitivity adjustment knob allows precise tuning for different metal sizes and detection distances. Clockwise rotation increases sensing sensitivity, allowing adaptation for various industrial or experimental conditions. An onboard LED indicator provides clear visual feedback whenever a metal object is detected, simplifying system debugging and installation in automation equipment or custom electronic assemblies.
Rugged Industrial Construction
A brass nickel‑plated flame‑retardant housing provides strong mechanical durability and corrosion resistance. The sealed structure supports IP66 protection, helping the inductive sensing module resist dust, moisture, and harsh environmental exposure. Reliable operation across a temperature range of −25℃ to 65℃ ensures stable sensing capability in manufacturing workshops, logistics machinery, or outdoor monitoring installations.
This ring‑type metal sensing device fits applications such as fastener counting, wire breakage monitoring, automated assembly inspection, and mechanical jam detection. Compact dimensions and long 2‑meter wiring simplify integration into production lines, robotic mechanisms, and industrial automation systems where precise metal object detection is required.
