Industrial-Grade RS485 Temperature & Humidity Sensor (1200m Transmission). This sensor is designed for harsh environments where standard sensors fail. Unlike I2C/UART sensors that are limited to short distances (< 2m), this RS485 module utilizes the standard Modbus RTU protocol to transmit stable data up to 1200 meters. Fully wrapped in a waterproof aluminum alloy shell, it is the ideal solution for greenhouse monitoring, warehouse management, and HVAC automation.
⚠️ Project Scope Check
Wiring distance < 2 meters? Save time and money, check our [Gravity: SHT31-F Digital Temperature and Humidity Sensor]. It's plug-and-play for simple projects.
Wiring distance > 10 meters? Or need to daisy-chain multiple sensors? You are on the right page. This is the professional choice for long-distance stability.
Hardware Setup Guide (Required Accessories)
Since this sensor outputs raw RS485 signals, it cannot be connected directly to a microcontroller's GPIO or a PC's USB port.
For PC Debugging: You need a [USB to RS485 Converter].
For Arduino / ESP32: You need an [RS485 Shield].
Power Supply: Requires 12V~36V DC external power (standard 5V from Arduino is insufficient).
Technical Quick Reference
We have extracted the key parameters from the manual for your quick setup:
Protocol: Standard MODBUS RTU
Baud Rate: 9600 (Default)
Wire Sequence: Yellow: RS485 A, White: RS485 B, Red: Power Input (12-36V), Black: GND
Figure: Pinout & Wiring Diagram of Industrial-Grade RS485 Temperature & Humidity Sensor
Temperature Measurement Range: -40 ~ 120℃
Humidity Measurement Range: 0 ~ 99.9%RH
Temperature Accuracy: ± 0.3°C (25°C)
Humidity Accuracy: ± 2%RH (25℃)
Sampling Cycle Period: 3 sec
Power Supply Voltage: 12 ~ 36V (DC)
Product Size: 200mm(L) × 15.7mm(D) / 7.87×0.62”
Output Signal: RS485 signal
Communication Protocol: standard MODBUS RTU protocol
Baud Rate: 9600 (default)
Display Resolution: Temperature: 0.1℃; Humidity: 1%RH
Product Net Weight: 110.0g
Sensitivity Attenuation Value: temperature<0.1℃/year; humidity<0.5%RH/year
Wire Sequence: yellow wire - RS485 A; red wire - power input; black wire - GND; white wire - RS485 B
Current consumption: Within 20mA
RS485 Temperature Humidity Sensor x1
