RS485 Temperature & Humidity Sensor
$29.90
SKU: SEN0438
  • $29.00 3+ items
  • $28.50 5+ items
  • $27.50 10+ items
High-precision RS485 sensor measures temperature (-40 to 120°C) and humidity (0-99.9% RH). It's waterproof, durable, and ideal for HVAC and automation applications.
Industrial-Grade RS485 Temperature & Humidity Sensor (1200m Transmission). This sensor is designed for harsh environments where standard sensors fail. Unlike I2C/UART sensors that are limited to short distances (< 2m), this RS485 module utilizes the standard Modbus RTU protocol to transmit stable data up to 1200 meters. Fully wrapped in a waterproof aluminum alloy shell, it is the ideal solution for greenhouse monitoring, warehouse management, and HVAC automation.
⚠️ Project Scope Check
  • Wiring distance < 2 meters? Save time and money, check our [Gravity: SHT31-F Digital Temperature and Humidity Sensor]. It's plug-and-play for simple projects.
  • Wiring distance > 10 meters? Or need to daisy-chain multiple sensors? You are on the right page. This is the professional choice for long-distance stability.
  • Hardware Setup Guide (Required Accessories)
    Since this sensor outputs raw RS485 signals, it cannot be connected directly to a microcontroller's GPIO or a PC's USB port.
  • For PC Debugging: You need a [USB to RS485 Converter].
  • For Arduino / ESP32: You need an [RS485 Shield].
  • Power Supply: Requires 12V~36V DC external power (standard 5V from Arduino is insufficient).
  • Technical Quick Reference
    We have extracted the key parameters from the manual for your quick setup:
  • Protocol: Standard MODBUS RTU
  • Baud Rate: 9600 (Default)
  • Wire Sequence: Yellow: RS485 A, White: RS485 B, Red: Power Input (12-36V), Black: GND
  • Pinout of Industrial-Grade RS485 Temperature & Humidity Sensor
    Wiring Diagram of Industrial-Grade RS485 Temperature & Humidity Sensor
    Figure: Pinout & Wiring Diagram of Industrial-Grade RS485 Temperature & Humidity Sensor
  • Temperature Measurement Range: -40 ~ 120℃
  • Humidity Measurement Range: 0 ~ 99.9%RH
  • Temperature Accuracy: ± 0.3°C (25°C)
  • Humidity Accuracy: ± 2%RH (25℃)
  • Sampling Cycle Period: 3 sec
  • Power Supply Voltage: 12 ~ 36V (DC)
  • Product Size: 200mm(L) × 15.7mm(D) / 7.87×0.62”
  • Output Signal: RS485 signal
  • Communication Protocol: standard MODBUS RTU protocol
  • Baud Rate: 9600 (default)
  • Display Resolution: Temperature: 0.1℃; Humidity: 1%RH
  • Product Net Weight: 110.0g
  • Sensitivity Attenuation Value: temperature<0.1℃/year; humidity<0.5%RH/year
  • Wire Sequence: yellow wire - RS485 A; red wire - power input; black wire - GND; white wire - RS485 B
  • Current consumption: Within 20mA
  • RS485 Temperature Humidity Sensor x1
  • FAQ
    Krizle.Santos Dec 13, 2025
    the sensor is good and accurate
    Senior.Vova Apr 22, 2025
    Simple configure and easy for use
