Background Suppression Photoelectric Sensor (30~120mm)
$29.90
SKU: FIT0770
  • $29.00 3+ items
  • $28.50 5+ items
  • $27.50 10+ items
Adjustable photoelectric switch with 15-350mm detection range, 0.5ms response time, ABS material, protection features, suitable for various applications.
This industrial-grade background suppression photoelectric sensor offers an adjustable detection range of 30–120mm (varies under operational conditions). Detection distance can be calibrated via a rotary knob, with a rapid response time of 1ms for stable performance. Constructed from ABS material, the sensor is environmentally friendly, durable, and immune to color and background interference. Minimal sensitivity to surface roughness ensures reliable detection. Integrated reverse polarity protection, over current protection, and over voltage protection enhance operational safety.
The module operates within a temperature range of -20°C to 55°C (non-freezing) and humidity levels of 35%–85% RH (non-condensing). Typical applications include SMT pick-and-place machines, packaging material inspection, security systems, and industrial automation control.
Dimension Diagram of Industrial-grade Background Suppression Photoelectric Sensor
User Manual
Operation (Detection Range Adjustment)
  • Factory Default: Pre-set to 30mm detection range. Green LED remains steady; Red LED activates upon detection.
  • Adjustment: After securing the sensor, align it with the target object. Turn the knob clockwise until the indicator switches from green to red to set the optimal detection range.
  • Light-On/Dark-On Mode Switch: Press and hold the button for 10 seconds. Release when the LED color changes to confirm mode switching.
    Wiring Instructions of Industrial-grade Background Suppression Photoelectric Sensor
    Note: For voltage measurement during installation or maintenance, connect a 1kΩ resistor between the brown (BROWN) and black (BLACK) wires. The output signal can then be measured between the blue (BLUE) and black (BLACK) wires.
    Precautions
  • Avoid direct exposure to the sensor’s light beam
  • Do not expose the sensor’s lens to intense light sources
  • Not suitable for detecting mirrored surfaces or specific colors
  • If condensation, oil, or dust accumulates on the lens, gently clean it with a dry, lint-free cloth
  • Maintain lens cleanliness in dusty or oily environments
  • The plastic housing is not impact-resistant; avoid mechanical stress
  • Model: PB-2S150N
  • Power Supply: 12–24V DC ±10%
  • Current Consumption: Max. 30mA
  • Output Type: NPN, 100mA max., residual voltage ≤1V
  • Detection Range: 30–120mm (varies by conditions)
  • Light Source: Red spot
  • Spot Size: Ø10mm (at 100mm distance)
  • Response Time: 1ms
  • Step Detection: Minimum 3mm, ≤10% of set distance (slight variations possible)
  • Contrast Ratio (Black/White): ≤5% (White: 95% reflectivity; Black: 5% reflectivity)
  • Detectable Objects: Opaque and semi-transparent materials
  • Adjustment: Rotary knob for distance sensitivity
  • Operating Mode: Light-On/Dark-On (toggle via 10-second button press)
  • Indicators:
            Red LED: Power/Output status
            Green LED: Operational stability
  • Protection: Reverse polarity, over current, over voltage
  • Ingress Protection: IP64
  • Ambient Light Tolerance:
            Indoor: ≤20,000 Lux
            Sunlight: ≤5,000 Lux
  • Operating Temperature: -20°C to 55°C (non-freezing)
  • Humidity: 35%–85% RH (non-condensing)
  • Housing Material: Plastic
  • Weight: Approx 30g
  • Background Suppression Photoelectric Sensor (30~120mm) x1
