Gravity: I2C LIS331HH Triple Axis Accelerometer (±6g/±12g/±24g)
$15.50
SKU: SEN0411
High-performance 3-axis accelerometer with ultra-low power, selectable scales, and 16-bit output. Suitable for navigation, VR, robotics, and more.
Purchase this product and earn 155 reward points, which are tied to VIP membership program. Learn More >
The LIS331HH is a high-performance 3-axis linear accelerometer with an ultra-low power consumption of 10uA. It offers user-selectable scales of ±6g/±12g/±24g and is capable of measuring accelerations with output data rates from 0.5Hz to 1KHz. The sensor is applicable to fields like navigation, smart agriculture, robotics, VR/AR, etc.
Connection-Diagram
Connection Diagram
  • Selectable scales: ±6g/±12g/±24g
  • 16-bit data output
  • Change I2C address by the toggle switch
  • Easy-to-use Gravity interface, no need to solder
  • Free-fall detection
  • Motion-activated functions
  • Gaming and virtual reality input devices
  • Operating Voltage: 3.3V~5V
  • Operating Current: 10uA(low power mode)/0.3mA(Normal mode)
  • Interface: Gravity-I2C
  • I2C Address: 0x19 (Default)/0x18 (Optional)
  • Selectable Scale: ±6g/±12g/±24g
  • Frequency: 0.5Hz~1KHz
  • 16-bit Data Output
  • 10000g High Shock Survivability
  • ECOPACK, RoHS and “Green” compliant
  • Module Size: 27*27mm/1.06*1.06”
  • Mounting Hole Size: inner diameter 3mm/outer diameter 6mm
  • Gravity: I2C LIS331HH Triple Axis Accelerometer x1
    Piko - Your ESP32-Powered Fitness Buddy
    Projects Piko - Your ESP32-Powered Fitness Buddy
    Iloke alusala
    Jun 03, 2025
    Piko - Your Friendly Fitness Buddy
    Projects Piko - Your Friendly Fitness Buddy
    Iloke Alusala
    May 29, 2025
    Triple Axis Accelerometer Sensor Selection Guide
    Blog Triple Axis Accelerometer Sensor Selection Guide
    Sep 15, 2021
