The weight sensor kit enables easy creation of a scale with built-in calibration. Compatible with Arduino, Raspberry Pi, and more, it measures up to 1kg.
Purchase this product and earn 249 reward points, which are tied to VIP membership program.
Learn More >
The weight sensor is a practical sensor close to daily life scenes. It can make many interesting applications by acquiring the weight information of objects, such as household electronic scales, daily necessities weighing, daily necessities remaining alarm,and Internet of Things weighing platforms.
This weight sensor kit is equipped with all the accessories needed to build the scale, which reduces the difficulty of structure construction so that anyone can quickly create an electronic scale to obtain the weight information of the object. In addition, because everyone has different installation methods and usage habits, the sensor needs to be calibrated. The traditional method is to use a separate calibration code to obtain the calibration value. To optimize this problem, the signal adapter board in this kit is built-in The calibration algorithm can calibrate the weight information with one key, and there is no need to run a separate code for calibration.
