Gravity: I2C H3LIS200DL Triple Axis Accelerometer (±100g/±200g)
$13.90
SKU: SEN0412
  • $13.60 3+ items
  • $13.30 5+ items
  • $12.90 10+ items
High-performance triple-axis accelerometer with ultra-low power, selectable scales ±100g/±200g, I2C interface, and applications in shock detection and crash tests.
The H3LIS200DL is a high-performance triple-axis linear accelerometer with an ultra-low power consumption of 10uA. It offers user-selectable scales of ±100g/±200g and is capable of measuring accelerations with output data rates from 0.5Hz to 1KHz.
Gravity: I2C H3LIS200DL Triple Axis Accelerometer Sensor
Connection Diagram
  • Selectable scales: ±100g/±200g
  • Change I2C address by the toggle switch
  • Easy-to-use Gravity interface, no need to solder
  • Shock detection and record
  • Free-fall detection
  • Vehicle crash test
  • Operating Voltage: 3.3V~5V
  • Operating Current: 10uA(low power mode)/0.3mA-0.4mA(Normal mode)
  • Interface: Gravity-I2C
  • I2C Address: 0x19 (Default)/0x18 (Optional)
  • Selectable Scale: ±100g/±200g
  • Frequency: 0.5Hz~1KHz
  • 8-bit Data Output
  • 10000g High Shock Survivability
  • ECOPACK, RoHS and “Green” compliant
  • Module Size: 27*27mm/1.06*1.06”
  • Mounting Hole Size: inner diameter 3mm/outer diameter 6mm
  • Gravity: I2C H3LIS200DL Triple Axis Accelerometer x1
    Triple Axis Accelerometer Sensor Selection Guide
    Blog Triple Axis Accelerometer Sensor Selection Guide
    Sep 15, 2021
