Flexible LED Filament (3V 260mm, Pink, 5 Pack)
$11.50
SKU: FIT0811
  • $11.20 3+ items
  • $11.00 5+ items
  • $10.60 10+ items
Flexible 3V LED filament, 260mm long, 2mm diameter, emits 360° light. Ideal for DIY projects, bendable, with separate positive and negative electrodes.
Purchase this product and earn 115 reward points, which are tied to VIP membership program. Learn More >
This flexible LED filament comes with a diameter of 2mm and a length of 260mm. The small round hole end is the positive electrode, and the non-porous end is the negative electrode. The filament is flexible and can be bent and folded at will. With a 3V power supply, it emits light 360 degrees. They can be used for DIY lighting decoration, DIY bulb ball, 360° full-angle light-emitting lamps, etc.
3V 260mm Flexible LED Filament Chip
Dimension
  • 3V power supply, high brightness, suitable for DIY
  • Small size, separate negative and positive electrodes
  • Flex LED filament chip, can be bent and folded at will
  • Length: 260mm/10.24”
  • Supply Voltage: 3V
  • Operating Current: 80mA
  • 3V 260mm Flexible LED Filament (Pink) x5
  • Only 6 Left
