This flexible LED filament Chip comes with a diameter of 2mm and a length of 260mm. The small round hole end is the positive electrode, and the non-porous end is the negative electrode. The filament is flexible and can be bent and folded at will. With a 3V power supply, it emits light 360 degrees. They can be used for DIY lighting decoration, DIY bulb ball, 360° full-angle light-emitting lamps, etc.
Dimension
Jul 01, 2025
I've been using those to make infinite mirrors. There is truly no easier solutions. I used to use LED strips, but those was kinda of brittle. Those LED filaments just seems so much more durable once they're set in place. Neon lights for the win!
