Flexible LED Filament (3V 260mm, 2200k, 5 Pack)
$10.00
SKU: FIT0812
  • $9.70 3+ items
  • $9.50 5+ items
  • $9.20 10+ items
A 3V flexible LED filament chip, 260mm long, emits light in 360°, ideal for DIY projects. It's bendable, with distinct positive and negative electrodes.
Purchase this product and earn 100 reward points, which are tied to VIP membership program. Learn More >
This flexible LED filament Chip comes with a diameter of 2mm and a length of 260mm. The small round hole end is the positive electrode, and the non-porous end is the negative electrode. The filament is flexible and can be bent and folded at will. With a 3V power supply, it emits light 360 degrees. They can be used for DIY lighting decoration, DIY bulb ball, 360° full-angle light-emitting lamps, etc.
3V 260mm Flexible LED Filament Chip
Dimension
  • 3V power supply, high brightness, suitable for DIY
  • Small size, separate negative and positive electrodes
  • Flex LED filament chip, can be bent and folded at will
  • Length: 260mm/10.24”
  • Supply Voltage: 3V
  • Operating Current: 80mA
  • 3V 260mm Flexible LED Filament Chip (2200k) x5
    Transparent Themed BB-8 Robot From Star Wars.
    Projects Transparent Themed BB-8 Robot From Star Wars.
    auroraAA
    Jun 27, 2025
    Dillon.Simeone Jul 01, 2025
    I've been using those to make infinite mirrors. There is truly no easier solutions. I used to use LED strips, but those was kinda of brittle. Those LED filaments just seems so much more durable once they're set in place. Neon lights for the win!
