The wind direction sensor (also known as wind vane) is a professional meteorological instrument used to measure horizontal wind direction. It integrates a hall sensor inside. The shell and weather vane are made of aluminum alloy material and use special mold precision die casting process, featuring small dimension tolerance and high surface accuracy. The sensor internal circuit is protected, which makes the sensor have the properties of high strength, weather resistance, anti-corrosion, and waterproof. The cable connector adopts corrosion-resistant military plug that ensures the long service life of the product.
A low-inertia wind direction sensor is used to sense the wind direction. When the wind direction changes, the tail wing rotates to drive the axle magnet to rotate through the shaft, thereby obtaining accurate wind direction information. It can detect the 16 natural wind directions. This sensor with high cost performance can be widely used in meteorology, ocean, environment, airports, ports, laboratories, industry, agriculture and transportation.
How does a wind vane work?
1. Wind Vane: The nose of the vane always points into the wind direction. This is because the wind applies a force on the flat surface of the vane, causing it to rotate until it aligns with the wind direction.
2. Signal Conversion: Attached to the vane is either a potentiometer or a magnetic sensor. This device converts the rotational movement of the vane into an electrical signal.
3. Signal Processing: The electrical signal is then processed to determine the wind direction.
Connection Diagram of RS485 Wind Direction Sensor, RS485 to UART Signal Adapter Module and Arduino Uno
Dimension Diagram of RS485 Wind Vane
Aug 27, 2025
Great build quality, and works really well.
Jan 22, 2025
has rugged construction suitable to withstand harsh environmental conditions. One of best Wind direction Sensor
