Gravity: LED Switch for Arduino / micro:bit (Blue)
$4.50
SKU: DFR0789-B
LED-illuminated self-lock switch button with visual feedback in various colors. Outputs High when pressed, Low when pressed again. Suitable for interactive projects.
This is a simple LED-illuminated self-lock switch button. It’s just like a basic switch button, but it lights up color(red/yellow/green/blue/white) when pressed down, which gives you visual feedback. These little buttons can be used with micro: bit to realize various fun interactive projects, such as switch, backlight keyboard, music player panel, and recording control panel.
Note: The module comes with self-lock function. When the button is pressed down, the module outputs High, and the LED lights up. When being pressed again, the module outputs Low and the LED turns off.
Gravity: LED Switch
Connection Diagram
  • Internal LED turns On when the button is pressed down
  • Operating Voltage: +3.3-5V (3.3V is recommended)
  • Output: digital
  • Connector: PH2.0-3P
  • Dimension: 27×26.5mm
  • Colors Available: red, yellow, green, blue, white
  • Gravity: LED Switch x1
  • Digital Sensor Connector x1
  • Review
    Ronald.Sdeyb Nov 14, 2021
    so good
