Gravity: DHT20 Temperature & Humidity Sensor for Arduino
$7.90
SKU: SEN0497
  • $7.80 3+ items
  • $7.60 5+ items
  • $7.40 10+ items
The DHT20 sensor improves accuracy, stability, and response speed for temperature and humidity measurements, using I2C protocol for diverse applications.
The DHT20 temperature & humidity sensor is the newly upgraded version of the DHT11. Data accuracy, stability, response speed, measurement range are greatly improved up.
DHT20 is a brand new ASIC dedicated chip, an improved MEMS semiconductor capacitive humidity sensor element and a standard on-chip temperature element. All sensors are factory calibrated and characterized by low power, high precision & stability, fast response, and strong anti-interference. Moreover, the DHT20 performance parameters of accuracy, power supply voltage, measurement range and response time have been enhanced greatly over the previous generation, making it more cost-effective.
Besides that, the DHT20 temperature & humidity sensor employs I2C digital output protocol, which is very suitable for HVAC, automobiles, data loggers, weather stations, home appliances, and other related temperature and humidity detection and controlled areas.
Application
Selection Guide
Temperature & Humidity Sensor Selection Guide
Figure
SKU
DFR0067
SEN0497
SEN0137
Communication Method
One wire
I2C
One wire
Operating Voltage
3.3-5V
3.3-5V
5V
Temperature range ± error
0~+50 ± 2 ℃
-40~+80 ± 0.5℃
-40~+80 ± 0.5℃
Humidity range ± error
20~90% ± 5%RH
0~100% ± 3%RH
0~100% ± 2%RH
Classic temperature and humidity sensor, low price, suitable for designs with low accuracy requirements
High-precision temperature and humidity sensor, DHT11 upgrade version, the same price but improved performance, using I2C communication, data is more stable
High-precision temperature and humidity sensor, high price, high detection range and accuracy
Add to Cart
  • Factory calibration
  • I2C digital output
  • Quick response, strong anti-interference ability
  • Low power, low cost
  • Compatible with mainboards like Arduino, micro:bit, ESP32, Raspberry Pi
  • Compatible with 3.3~5.5V main controller
  • HVAC
  • Automobiles
  • Data loggers
  • Weather stations
  • Home appliances
  • Operating Voltage: 3.3V ~ 5.5V DC
  • Operating Current: <1mA
  • Output Signal: I2C (0×38)
  • Temperature Range: -40 ~ +80°C ±0.5°C
  • Humidity Range: 0~100%RH ±3%RH (25°C)
  • Resolution: 0.01℃, 0.024%RH
  • Storage Condition: 10℃-50℃, 20-60%RH
  • Board Dimension: 22*33 mm/0.87*1.30”
  • Mounting Hole Size: Inner diameter 3.1mm (0.13”)/Outer diameter 6 mm (0.24”)
  • Temperature and Humidity Sensor x1
  • Gravity-4Pin I2C Sensor Connector (30cm) x1
    Making a Desktop Geiger Counter with Unihiker --- Real-Time Nuclear Radiation Monitoring
    Projects Making a Desktop Geiger Counter with Unihiker --- Real-Time Nuclear Radiation Monitoring
    Afra
    Dec 01, 2023
    Kaj Ronny.Nilsen Dec 08, 2025
    Nice I2C sensor, easy to setup and use, libraries are available or easily modified.
