A variety of Gravity sensors and modules compatible
Plug-and-play, no soldering required
Specially designed for FireBeetle 2 series (M0, ESP32-E), this Gravity IO expansion shield offers various ports including digital, analog, I2C, UART, SPI, etc. Also, it comes with power input socket for connecting external power supply as well as EN pin for cutting off the power supply to main-board.
The Gravity IO shield allows a convenient connection between DFRobot Gravity sensors and FireBeetle 2 series, no soldering required.
Note: This expansion board is specifically designed for FireBeetle 2 controllers series:M0, ESP32-E, not suitable for the original FireBeetle Series.
Dec 19, 2025
Does what says on the tin. A very useful addition to a developer's kit
