This is a PWM driver board with four adjustment methods, namely, Python code direct control, PC host computer control, UART communication programming control, and potentiometer manual control.
It is used in application scenarios such as DC motor speed control and light adjustment.
This product supports 5V~24V wide voltage input, and has a load capacity of 10A, which can drive a DC motor of about 10W or a LED strip light of about 5 meters.
It is suitable for water pump water volume control, cooling fan speed control, light brightness adjustment, power tool transformation, motor/LED strip product testing, motor speed automation control, lighting effect automation control and other scenes.
Board Overview
Product Dimension
Python code programming, no motherboard or adapter required.
Windows software control, no programming required,
Convenient for long-term use of embedded equipment.
Manual control, no programming required.
The protocol is public, and you can flexibly customize your own control method.
Suitable for various motors and light strips.
1. Connect the USB interface, you can directly use Python code to automatically control the motor speed and lighting effect. No additional motherboard or adapter is required.
2. Can be very conveniently used on Windows computers, Apple computers, Raspberry Pi, industrial computers or LattePanda.
1. When remaking a PC cooling fan, cooling water pump, etc, you can manually control the device on PC, or make it be automatically adjusted by reading the CPU temperature.
2. Because the host computer can accurately adjust the frequency and duty ratio, this driver can be used to test dc motor or light strip products, or to optimize small equipment.
3. Make a small fan whose wind speed can be automatically adjusted or controlled on the computer. Just plug in the USB to use.
4. MODBUS communication protocol.
1. Create a project with special effects, or turn it on at a specific time, or adjust lighting effects, or use it with sensors. For example, a fan that automatically adjusts the wind force, and a light strip that automatically changes its brightness.
2. Automatic control of the water output of the fish tank or watering pump.
3. Automatic control of festival atmosphere lights.
1. Home appliance renovation, making adjustable fans.
2. Electric tool production, transformation, adjustable speed.
3. lighting effects control of light strip.
External potentiometer adjustment
UART communication control
USB port host computer control
Python control
