Fermion: BMP390L Digital Barometric Pressure Sensor (Breakout)
$10.90
SKU: SEN0423
  • $10.70 3+ items
  • $10.50 5+ items
  • $10.20 10+ items
Industrial-grade digital barometric pressure sensor with high precision, stability, and low power consumption, suitable for indoor positioning and various applications.
BMP390L, an industrial-grade dedicated digital air pressure sensor developed by Bosch, has the characteristics of extremely high temperature stability, low drift, low power consumption and low noise. Its sleep current is only 54uA, the highest power consumption measurement mode is 650uA, and the noise impact is less than 0.02Pa.
The maximum error of absolute accuracy is less than 50Pa, and the relative accuracy can reach 3 Pa (equivalent to 25cm), which is 166.7% higher than that of the previous generation, ensuring the measurement accuracy.
The long-term stability of this model is far ahead of the previous generation, and the 12-month long-term stability error is only 16Pa. Its precision, stability and low power consumption make it very suitable for indoor positioning and other scenes that GPS signals can't cover, and it can be safely integrated into equipment.
Fermion:BMP390L Digital Barometric Pressure Sensor (Breakout)
Connection Diagram
Selection Guide
Pressure/Altitude Sensor Selection Comparison Table
Figure
SKU
SEN0664
SEN0666
SEN0665
SEN0667
SEN0423
SEN0251
Add to Cart
Chip/Module Type
Bosch BMP585
Bosch BMP585
Bosch BMP581
Bosch BMP581
Bosch BMP390L
Bosch BMP388
Size/Volume
Compact module
Ultra-small PCB
Compact module
Ultra-small PCB
Ultra-small PCB
Compact module
Power Consumption
∼700μA
200μA / 2μA sleep
∼700μA
200μA / 2μA sleep
54μA sleep / max ∼650μA
~0.5mA
Interface Protocol
I2C / UART, plug & play
I2C / SPI / I3C
I2C / SPI / I3C
I2C / SPI
I2C / SPI
Accuracy / Key Features
±0.3hPa / Industrial protection
±0.3hPa + Waterproof & Chemical resistant
±0.3hPa / Ultra-low noise
±0.50hPa / ±3Pa (∼±0.25m) / High stability
±8Pa (∼±0.5m) / Temp ±0.5∘C
Ideal Scenarios
Industrial / Agricultural environmental detection
Outdoor weather stations / Environmental monitoring device integration
Drone altitude control / High-precision pressure data logging
Battery-powered IoT / Micro-drone project integration
Drone altitude control / High-precision pressure & altitude detection
Basic pressure measurement / Indoor positioning / GPS enhancement
  • High precision (absolute deviation <50Pa, relative accuracy <3Pa)
  • High long-term stability (±16Pa/year)
  • Extremely high temperature stability and low drift characteristics
  • Low power consumption (sleep current: 54uA, working current <650uA)
  • Asset tracking & navigation(floor detection)
  • Water-level measurement
  • Vertical velocity indication(e.g. rise/sink speed)
  • Enhancement of GPS navigation
  • Outdoor navigation & applications
  • Health care applications(e.g. spirometry)
  • AR & VR applications
  • Context awareness
  • Flight stabilization
  • Clogging detection
  • Working Voltage: 3.3V
  • Working Current: sleep mode (54uA) / normal mode (357~650uA)
  • Interface Mode: I2C/SPI
  • I2C Address: 0x77 (default address)/0x76 (optional: SDO pin connects to GND)
  • Pressure Sensing Range: 300~1250 hPa
  • Relative Accuracy: ±0.03hPa (equivalent to 25cm) (@700-1100hPa, 25-40°C)
  • Absolute Accuracy: ±0.50hPa
  • Temperature Deviation Coefficient: ±0.6Pa/K (@900hPa, 25-40°C)
  • Long-term Stability: ±0.16hPa/year
  • ODR Accuracy: ±2~±12%
  • Start-up Time: 2ms
  • Operating Temperature Range: -40℃~+85℃ (Full precision measurement can be used under 0℃~+65℃)
  • Module Size: 15*20 (mm) / 0.59*0.79 (inch)
  • Fermion: BMP390L Digital Barometric Pressure Sensor (Breakout) x1
  • 2.54-7P Black Single-row Pin Header x1
  • 2.54-4P Black Single-row Pin Header x1
    Only 14 Left
