Raspberry Pi PLC Industrial Controller (Optoisolated Output)
$560.00
SKU: DFR0908
A professional PLC with Raspberry Pi technology, featuring 36 digital inputs, 16 analog inputs, multiple communication ports, and runs Linux or Raspberry Pi OS.
Purchase this product and earn 5600 reward points, which are tied to VIP membership program. Learn More >
This equipment based on the Raspberry Pi technology is designed for professional use.
This PLC has up to 36 Digital Inputs, 16 Analog Inputs, 8 Analog Outputs, and 6 Interrupts. It also contains several communication ports like, the CAN bus, double Ethernet port, double RS-485, WiFi, Bluetooth, which provides great flexibility and control.
This PLC runs a Linux or a Raspberry Pi OS.
The PLC Raspberry Pi has the most important features to improve the speed process, use a wide range of connections and secure your data and your operating system. It uses UPS uninterruptible power supply. Compared to most common PLCs, it allows high-speed processing and multi-process to work with applications in real time. Besides, the PLC Raspberry Pi has an internal clock that guarantees the current time and date to keep track of the right time.
Raspberry Pi PLC (Optoisolated Output)
  • With great flexibility and control
  • Runs a Linux or a Raspberry Pi OS
  • IoT Project
  • Industrial environment using Linux
  • Model Type: Raspberry PLC
  • Input Voltage: 12~24Vdc (fuse protection (2.5A) polarity protection)
  • Input Rated Voltage: 24Vdc
  • Rated Power: 30W
  • Maximum Current: 1.5A
  • Size: 101*701*119.5mm
  • SRAM: 2/4/8 GB
  • Communication: I2C, Ethernet (x2), USB (x4), RS485 (x2), SPI, WiFi, Bluetooth, Serial TTL, CAN, mircoSD, RTC
  • Operating Voltage Range: 11.4~25.4Vdc
  • Operating Temperature: 0º to 50ºC with Raspberry OS Lite / 0º to 40ºC with Raspberry OS Desktop
  • Working Humidity: 10%~90% (non-condensing)
  • Storage Temperature: -20℃~60℃
  • Weight: 378g
  • I/O Port Voltage Range
              Analog I/Os Voltage: 0~10Vdc
              Digital isolation I/Os Voltage: 5~24Vdc
  • Raspberry Pi PLC (Optoisolated Output) x1
  • Only 7 Left
