10 I/Os PLC Module - CPU Arduino NANO (Optoisolated Output)
$123.00
SKU: DFR0898
A 10 I/Os industrial PLC module with optoisolated output, based on Arduino Nano, supports RS485, Ethernet, ideal for monitoring and automation tasks.
Purchase this product and earn 1230 reward points, which are tied to VIP membership program. Learn More >
This 10 I/Os industrial PLC module(Optoisolated output) based on Arduino NANO provides a simple and cost-effective solution to the applications of industrial monitoring and control. It is easy to install and configure, and very flexible thanks to the Open Source-based hardware.
With standardized PLC connectors, the 10 I/Os module supports RS485, Ethernet, and optoisolated input / output, which could be well suitable for the monitoring, control and automation of your machines, alarms, elevator control, product lines, installations among the most typical applications such as fans, pumps, air conditioning, full HVAC solutions, control of AC and DC motors.
Board Overview
  • With 10 I/O interfaces
  • Standardized connectors
  • Supports RS485
  • Control and automation of machines
  • Control of AC and DC motors
  • MCU: Arduino Nano
  • Power Input: 12-24V DC
  • Input Rated Voltage: 24V DC
  • Rated Power: 30W
  • Maximum Current:1.5A
  • Clock Speed: 16MHz
  • Flash: 32KB
  • SRAM: 2KB
  • EEPROM: 1KB
  • Communication: USB, RS485, Ethernet
  • Operating Voltage Range: 11.4~25.4V DC
  • Digital Input: 3.3-24V DC(10Hz) / 220V AC
  • Digital Isolated Output: 24V DC
  • Working Temperature: 0℃~60℃
  • Working Humidity: 10%~90%
  • Storage Temperature: -20℃~60℃
  • Ethernet Port
  • RS485
  • TCP IP
  • Modbus TCP
  • Modbus RTU
  • 10 I/Os PLC Module CPU Arduino NANO (Optoisolated Output) x1
  • Out Of Stock
