3-Pin LED Strip Connector Cable (5PCS)
$2.90
SKU: FIT0863
  • $2.80 3+ items
  • $2.70 5+ items
  • $2.60 10+ items
Connect 10mm RGB LED strips without soldering using a 3-pin snap-down connector. Ideal for lighting decoration, supports up to 5A current. Comes in a pack of five.
Is there a way to join two pieces of cuttable LED strips together without soldering? Yes, there is.
This 3-Pin solderless strip connector comes with wire and adopts a snap-down design at both ends, which makes a firm and easy connection of 10mm wide 3-wire RGB LED strips. Just align and snap them together, job done!
3PIN LED Strip Connector Cable (5Pcs)
Product Assembly
Product Dimension
  • Snap-down design, firm connection
  • Connect LED strips without soldering
  • Lighting Decoration
  • Suitable LED Strip Width: 10mm
  • Suitable LED Strip Thickness: 0.2mm-0.4mm
  • Current: Max 5A
  • Operating Temperature: -45℃~+105℃
  • 3-Pin Connector
  • 3-Pin LED Strip Connector Cable (5PCS) x1
