3-Pin LED Strip Connector Cable-Single Head (5PCS)
$2.90
SKU: FIT0865
  • $2.80 3+ items
  • $2.70 5+ items
  • $2.60 10+ items
This solderless 3-Pin LED strip connector features a snap-down design for firm connections, a 20cm wire, DuPont connector, and supports up to 5A current.
Is there a way to join two pieces of cuttable LED strips together without soldering? Yes, there is.
This 3-Pin solderless LED strip connector comes with 20cm wire connected to a DuPont-style female connector, and the other end employs snap-down design that makes a firm connection. Besides, the clearly marked polarity and color-labeled wires make it very convenient to use.
3PIN LED Strip Connector Cable-Single Head(5pcs)
  • Snap-down design, firm connection
  • Connect LED strips without soldering
  • Lighting Decoration
  • Suitable LED Strip Width: 10mm
  • Wire Length: 20cm
  • 3-Pin LED strip
  • DuPont Connector
  • Current: Max 5A
  • Operating Temperature: -45℃~+105℃
  • Wire: 22AWG, UL certificated
  • Suitable LED Strip Thickness: 0.2mm-0.3mm
  • 3-Pin LED Strip Connector Cable-Single Head (5PCS) x1
