Note: micro:bit board and batteries are not included.
What’s new in Maqueen Plus V2?
1. Two versions to choose from: 4 AA battery and 18650 battery
2. New plastic box with a deeper base, enough room for the assembled car
3. Frosted acrylic protective plate at the bottom, more durable and reliable
4. The number of Line-tracking sensors has changed from 6 to 5, more convenient to program and optimize line-tracking codes
5. Employs the motors whose parameters are the same as previous Maqueen, running steadily and smoothly
6. Changes ultrasonic sensor to SR04, easier to install
7. Add 4 RGB ambient lights at the base, RGB car lights have been changed to LEDs
8. Delete the less usable magnetic encoder
micro:Maqueen Plus V2 (18650 Battery) with HUSKYLENS
micro:Maqueen Plus V2 (18650 Battery) with HUSKYLENS and micro:bit
micro:Maqueen Plus V2 (18650 Battery) with micro:Maqueen Mechanic
micro:Maqueen Plus V2 (18650 Battery) with micro:Maqueen Mechanic and micro:bit
micro:Maqueen Plus V2 (18650 Battery) with Mechanic, micro:bit and Gamepad
Maqueen Plus V2 is the latest version of the STEAM educational robot Maqueen Plus. Optimized with more expansion ports, larger capacity power supply, and larger body, it is fully compatible with more peripheral components like HuskyLens AI camera, Maqueen Mechanic Kits, which makes it an accessible STEAM robot teaching tool for primary and secondary students. Maqueen Plus V2 is not only suitable for classroom teaching, but also can be used for after-school extended exercises and robot competitions.
Besides all the functions of Maqueen Lite, it offers richer and more flexible functions and stronger performance. Whether you have ever used Maqueen Series products or not, you’ll find it very easy to get started.
Aug 26, 2025
I’m very satisfied with my purchase, the product exceeded my expectations.
