micro:Maqueen Plus V2 (18650 Battery) with micro:Maqueen Mechanic
$94.50
SKU: MBT0021-EN-18650-3
The product is an educational robot kit with expansion ports, versatile functions, and compatibility with AI cameras, suitable for STEM learning and competitions.
Purchase this product and earn 945 reward points, which are tied to VIP membership program. Learn More >
Note: This product includes micro: Maqueen Plus v2 and micro:Maqueen Mechanic (Forklift, Push, Beetle, and Loader).
micro: bit board and batteries are not included.
What’s new in Maqueen Plus V2?
1. Two versions to choose from: 4 AA battery and 18650 battery
2. New plastic box with a deeper base, enough room for the assembled car
3. Frosted acrylic protective plate at the bottom, more durable and reliable
4. The number of Line-tracking sensors has changed from 6 to 5, more convenient to program and optimize line-tracking codes
5. Employs the motors whose parameters are the same as previous Maqueen, running steadily and smoothly
6. Changes ultrasonic sensor to SR04, easier to install
7. Add 4 RGB ambient lights at the base, RGB car lights have been changed to LEDs
8. Delete the less usable magnetic encoder
Maqueen Plus V2 is the latest version of the STEAM educational robot Maqueen Plus. Optimized with more expansion ports, larger capacity power supply, and larger body, it is fully compatible with more peripheral components like HuskyLens AI camera, Maqueen Mechanic Kits, which makes it an accessible STEAM robot teaching tool for primary and secondary students. Maqueen Plus V2 is not only suitable for classroom teaching, but also can be used for after-school extended exercises and robot competitions.
Besides all the functions of Maqueen Lite, it offers richer and more flexible functions and stronger performance. Whether you have ever used Maqueen Series products or not, you’ll find it very easy to get started.
  • No complex assembly, get started in minutes
  • More IO expansion ports: 3.3V IO x7, 5V IO x3, I2C x3
  • 5 line-tracking sensors, reliable and flexible
  • Larger body, more flexible expansion methods
  • Two versions to choose from: AA battery and 18650 battery
        AA battery version supports 1.2V Ni MH battery or 1.5V alkaline battery, while 18650 battery version supports 3.7V 18650 battery
  • Works well with HuskyLens AI camera
  • Rich peripherals: IR receiver, LED car lights, RGB ambient lights, buzzer, ultrasonic sensor, etc.
  • Frosted acrylic protective plate at the bottom
  • Storage box with a deeper base to provide enough room for the assembled Maqueen Plus car
  • STEM Education
  • Power Supply: MBT0021-EN-18650: 18650 Lithium battery (3.6V or 3.7V) x 1, onboard charging circuit, MicroUSB and TYPE-C charging interfaces, 4 hours to charge fully
  • Support micro:bit V1 and V2
  • N20 All-metal Gear Motor x 2
  • Buzzer x 1
  • 5V IO (P0 P1 P2) x 3
  • 3.3V IO (P0 P1 P2 P8 P12 P13 P14 P15)
  • 3.3V I2C x 2
  • 5V I2C x 1
  • Large Size LED Car Lights x 2
  • RGB Ambient Lights x 4
  • Line-tracking Sensor x 5
  • Line-tracking Sensor with One-key Calibration
  • IR Receiver x 1
  • SRO4 Ultrasonic Module x 1
  • Dimension: 136mm×65mm/5.35×2.56"
  • Programming Platform: Mind+, MakeCode
  • Wiki Address:
  • MakeCode Library Address: https://github.com/DFRobot/pxt-DFRobot_MaqueenPlus_v20
    Maqueen Plus V2 (18650 battery):
  • Maqueen Plus V2 (18650 battery) Vehicle body x 1
  • (Note: the motor, vehicle wheel, support wheel, and battery panel have been installed before delivery)
  • H-SR04 Ultrasonic Sensor x 1
  • Line-tracking Map x 1
  • micro: Maqueen Mechanic (Forklift, Push, Beetle, and Loader):
  • Loader Servo Panel x 1
  • Loader Bucket x 1
  • Pan-tilt-zoomMount Plate x 2
  • Trolley Plate x 1
  • Ultrasonic MountHolder x 1
  • Arm Servo Base x 1
  • Arm Baseplate x 1
  • Arm Linkage x 3
  • Arm Plate x 1
  • Servo Arm Linkage x 1
  • Forklift Plate x 1
  • Gripper Upper Arm x 2
  • Gripper DrivenForearm x 1
  • Gripper ServoForearm x 1
  • Gripper Panel x 1
  • M3*35mm Copper Bolt x 2
  • M3*25mm Copper Bolt x 2
  • M3*15mm Copper Bolt x 6
  • M3*17mm Copper Bolt x 3
  • 9g servo x 2
  • M2.5*5mm nut x 12
  • M3*5mm nut x 45
  • Installation Manual x 1
  • Review
    Frank.Schmidt Apr 13, 2024
    This is a great product for kids' education and machine learning. Good service and great price! The MakeCode system is very easy to use. The camera is very good to recognize objects and faces and simple QR codes called April Tags. Color recognition is not accurate because room lighting varies with more or less sunlight. V2 Microbit is best not V1 or 1.5 . The DFRobot Wiki is quite good also. The battery is rechargeable.
