Fermion: ENS160 Smart Air Quality Sensor - TVOC/eCO2/AQI Monitor (Breakout)
$14.90
SKU: SEN0515
  • $14.60 3+ items
  • $14.30 5+ items
  • $13.80 10+ items
Indoor air quality sensor ENS160 detects TVOC, eCO2, and AQI using TrueVOC™ technology for accurate, stable readings. Supports I2C/SPI interfaces.
The ENS160 sensor delivers lab-grade accuracy for TVOC (0-65,000ppb), eCO2 (400-65,000ppm), and AQI measurements - essential for healthy homes, offices, and commercial spaces.
Multi-Parameter IAQ Analysis
Simultaneously tracks three critical air quality metrics: volatile organic compounds (TVOC), equivalent CO2 (eCO2), and comprehensive Air Quality Index (AQI).
Rapid 3-Minute Warm-Up
TrueVOC™ technology achieves operational readiness 67% faster than conventional sensors, delivering actionable data when you need it most.
Self-Calibrating Accuracy
Built-in automatic baseline correction maintains ±15% measurement accuracy over years of continuous operation - no manual recalibration needed.
Smart Home Ready
I2C/SPI outputs integrate seamlessly with ESP32, Raspberry Pi, and Arduino systems for real-time air quality dashboards and automation triggers.
Fermion: ENS160 Air Quality Sensor (Breakout)
Board Overview
  • Pre-loaded US EPA AQI algorithms
  • Compact 300mm² footprint fits any enclosure
  • Compatible with FireBeetle ESP32 systems
  • Sample code for Home Assistant/MQTT
  • Automatic temperature/humidity compensation
  • Whole-house ventilation control
  • Office building air quality monitoring
  • School/healthcare facility IAQ systems
  • Smart thermostat integration
  • Kitchen range hood automation
  • Measurement Ranges:
    TVOC: 0-65,000ppb
    eCO2: 400-65,000ppm
    AQI: 1-5 (US EPA standard)
  • Response Time: <1 minute
  • Warm-Up: 3 minutes to optimal accuracy
  • Operating Voltage: 3.3V DC
  • Interfaces: I2C (0x52/0x53), SPI
  • Dimensions: 20×15mm (0.79×0.59")
  • Temperature Range: -40°C to 85°C
  • Humidity Tolerance: 5-95% RH
  • Fermion: ENS160 Air Quality Sensor x1
  • 2.54-4P Black Single Pin Connector x1
  • 2.54-7P Black Single Pin Connector x1
    Certifications
    How to Create an Indoor Temperature, Humidity, and Air Quality Monitoring System with ESP32-C6
    Projects How to Create an Indoor Temperature, Humidity, and Air Quality Monitoring System with ESP32-C6
    auroraAA
    Jul 09, 2024
    Alan .Arias Diosdado Oct 29, 2025
    Tal como se describe en la página. Excelente producto
