ToF Laser Ranging Module for Outdoor (15m)
$42.90
SKU: SEN0524
  • $42.00 3+ items
  • $41.00 5+ items
  • $40.00 10+ items
A compact outdoor laser sensor with 5cm-15m range, 1mm resolution, and 100K LUX light resistance. It supports UART, I2C, I/O modes, ideal for drones and automation.
Purchase this product and earn 429 reward points, which are tied to VIP membership program. Learn More >
This is a ToF-based single-point laser ranging sensor for outdoor use. It has 100K LUX resistance to strong ambient light, which means there will be no problems at all when using it on sunny days.
Outdoor Laser Ranging Module (15m)
With a detection range of 5cm~15m, the product features distance resolution 1mm, 50Hz data update frequency, 1~2° FOV, and supports UART, I2C, and I/O multiple communication modes(support active and query output data in UART mode).
Small in size, there are standard screw holes reserved on the side and bottom of the module, which is convenient for installation in various places. It can be widely used in the fields of drone height setting, route planning, smart car competition and transportation, industrial automation, high-speed measurement, safety monitoring, etc.
  • 100K LUX resistance to strong ambient light
  • Supports UART, I2C, and I/O multiple communication modes
  • Convenient for installation
  • Drone height setting
  • Route planning
  • Smart car competition and transportation
  • Industrial automation
  • High-speed measurement and safety monitoring
  • Measuring Range: 5cm~15m
  • Measurement Resolution: 1mm
  • Ranging Accuracy: [0. 05m, 2m]±2cm, std<0. 5cm; (2m, 15m]±2%, std<8cm
  • Field of View (FOV): 1~2°
  • Output Mode: UART, I2C, I/O (support active and query output in UART mode)
  • Refresh Rate: 50Hz
  • I2C Default Slave Address: 0x08
  • Wavelength: 750~830nm
  • Anti-Ambient Light: 100K Lux
  • Power Supply Voltage: 3.7~5.2V, reverse connection protection
  • Power Consumption: 610mW
  • Working Temperature: -10~60℃
  • Size: 22.7*28*13.6mm / 0.89*1.10*0.54 inch
  • Weight: 7.7g
  • Outdoor Laser Ranging Module(15m) x1
  • GH1.25 4P Adapter Cable x1
  • Screws x2
    Solid State LiDAR (Laser Radar) Selection Guide
    Blog Solid State LiDAR (Laser Radar) Selection Guide
    Mar 13, 2020
    Only 18 Left
