WS2812-24 RGB LED Ring Lamp
$11.90
SKU: DFR0888-24
  • $11.70 3+ items
  • $11.30 5+ items
  • $11.00 10+ items
This RGB LED Ring offers full-color illumination for interactive projects, supports cascading control, and works with multiple programming platforms.
WS2812-24 RGB LED Ring brings vibrant programmable lighting to creative electronics, robotics builds, and interactive installations. The circular lighting module integrates 24 addressable WS2812 LEDs capable of producing 16 million colors with smooth animation effects. Compact dimensions allow easy integration into wearables, robot displays, and decorative lighting systems. A single‑wire control interface simplifies integration with popular controllers such as Arduino, while the ring layout enables eye‑catching radial animations. This addressable RGB lighting module serves equally well in rapid prototypes, creative coding experiments, and STEM Education environments where visual feedback enhances learning and engagement.
Individually Addressable WS2812 RGB Lighting
This circular RGB lighting board integrates 24 WS2812 smart LEDs capable of producing 16 million color combinations. Each LED can be individually programmed, enabling complex animation effects such as rotating patterns, breathing lights, progress indicators, and spectrum displays. The addressable LED architecture makes this programmable light ring suitable for expressive visual feedback in robotics, interactive art installations, and electronic prototypes requiring colorful dynamic illumination.
Figure: WS2812-24 RGB LED Ring Lamp
Compact Circular Layout for Visual Interfaces
The compact ring-shaped lighting module distributes LEDs evenly around a circular board, enabling directional indicators, dial-style displays, and animated progress rings. Such geometry works well for clocks, countdown timers, compass-style indicators, and decorative robotic lighting. Small form factor allows seamless installation in enclosures, panels, and custom projects while still delivering bright, uniform illumination across the entire LED ring.
Figure: LED Ring Size
Single-Wire Control and Cascading Expansion
The programmable LED ring operates through a one‑wire digital communication interface, significantly simplifying wiring and microcontroller integration. Multiple LED rings can be chained together through the IN and OUT data terminals, allowing expansion into larger lighting arrays while maintaining a single control signal. This cascade capability enables scalable decorative lighting systems, animated displays, and synchronized illumination patterns across multiple rings.
Figure: Cascade Control
Such colorful addressable lighting hardware suits a wide range of creative applications including robot decoration, lottery turntables, interactive displays, countdown timers, and artistic lighting effects. The programmable RGB ring also integrates easily into educational electronics kits, rapid prototyping platforms, and interactive installations where dynamic visual feedback enhances both functionality and aesthetics.
Selection Guide
RGB LED Ring Selection Guide
Figure
SKU
DFR0888-12
DFR0888-16
DFR0888-24
LED Ring
RGB LED Ring - 12 Beads
RGB LED Ring - 16 Beads
RGB LED Ring - 24 Beads
Inner Ring Diameter
2.6cm(1.02 inch)
4.9cm(1.93 inch)
7.2cm(2.83 inch)
Outer Ring Diameter
4.7cm(1.85 inch)
7.0cm(2.76 inch)
9.3cm(3.66 inch)
Add to Cart
  • Full-color WS2812 RGB
  • 1-Wire bus control
  • Support cascading of multiple LED rings
  • Support multiple programming platforms: Mind+, MakeCode, Arduino IDE
  • STEM Education
  • Working Voltage: 3.3~5V
  • Maximum Operating Current: <100mA
  • Interface Type: PH2.0-3P
  • Lamp Bead Model: WS2812
  • Number of Lamp Beads: 24
  • Color: 16 million colors
  • WS2812-24 RGB LED Ring x1
  • Gravity: Digital Sensor Cable (30cm) x1
    Florian.Hauenstein Jan 31, 2025
    Funktioniert einwandfrei, leds sind stark und kräftig
