The Beetle ESP32-C3 is a miniature controller based on the ESP32-C3 32-bit single-core RISC-V processor. It operates at a main frequency of 160 MHz with 400KB SRAM and 4MB Flash. The board measures 25mm x 20.5mm and supports Wi-Fi (IEEE 802.11b/g/n) and Bluetooth 5 (LE) communication. It features an onboard lithium-ion battery charging management function with a maximum charge current of 400mA. The device provides 13 digital I/O ports. An expansion board is included for easier soldering and connectivity, featuring an easy-to-connect GDI. It can be programmed via Arduino IDE, ESP-IDF, and MicroPython.
Mini Size and User-Friendly
On a coin-size board of 25*20.5 mm,The Beetle ESP32-C3 is up to 13 IO ports broken out, so you don't have to worry about running out of IO ports when making projects. Moreover, its mini size effortlessly integrates into a miniature devices and offering both powerful functions and connectivity.
For instance smart wearables, the Beetle ESP32-C3 microcontroller's mini size make it an ideal choice for intelligent wearables like smartwatches and smart glasses. It can connect with smartphones, enabling health monitoring, and delivering message notifications, it accomplishes all this without sacrificing the device's form factor or increasing its weight.
Beetle ESP32-C3 Mini Size
The equipped expansion board for Beetle ESP32-C3 brings out more power sources without increasing product volume, more convenient for solder. Besides, the onboard easy-to-connect GDI saves the trouble of wiring when using a screen.
Pin Diagram
More Safety
Meanwhile, the li-ion battery charging management function is integrated on the board which allows for directly connecting the li-ion battery without extra modules, while ensuring the application size and safety.
Dual-Mode Communication
Beetle ESP32-C3 supports WiFi and Bluetooth 5 (LE) dual-mode communication that reduces the difficulty of networking, and also both Bluetooth Mesh protocol and Espressif WiFi Mesh are supported for more stable communication and a larger coverage area, applicable to a wide range of IoT application scenarios.
Detailed tutorial
Detailed tutorials for Beetle ESP32-C3 are provided for users to use the controller’s WiFi function, such as connecting to IoT platforms like Aliyun, IFTTT, etc. Or users can use various sensors and actuators from DFRobot to build up IoT systems.
Beetle ESP32-C3 can be programmed by Arduino IDE, ESP-IDF, MicroPython, C, and Python are both supported.
V2.0.0 Modification: BOOT (IO9) and RST buttons are added for entering download boot mode and resetting more easily.
Wide range of application fields
Basic Parameter
Hardware Parameter
WiFi
Bluetooth
Ports
