The 2.3KG Serial Bus Servo is a compact TTL‑communication actuator designed for robotics mechanisms requiring precise positioning and scalable multi‑servo control. A miniature smart servo architecture enables daisy‑chain networking so multiple actuators operate independently or synchronously through serial commands. Up to 253 units can share the same communication line, each assigned a unique ID for coordinated motion control. With 180° motion in a 500–2500 μsec pulse range and 2.3kg·cm stall torque at 6V, this compact robotics motion module delivers reliable performance for educational robots, lightweight mechanisms, and embedded motion systems where size, responsiveness, and programmable control are essential.
Figure: Serial bus micro servo module
Daisy‑Chain TTL Serial Bus Control
This serial communication servo supports TTL bus networking, allowing as many as 253 actuators to connect in series on a single communication line. Each programmable servo receives an individual ID, enabling precise individual positioning or synchronized multi‑axis motion. A communication baud rate up to 1 Mbps ensures fast response and smooth coordinated movement. Adjustable rotation limits and configurable motion parameters provide flexible integration for robotic joints, multi‑servo mechanisms, and experimental motion control platforms used in embedded electronics and automation projects.
Hybrid Gear System for Balanced Speed and Strength
A mixed gear train design combines the advantages of plastic and metal transmission components to optimize mechanical performance. Low‑noise plastic gears operate during high‑speed movement to reduce vibration and mechanical wear, while metal gears engage during lower‑speed high‑load conditions to increase durability and torque reliability. This hybrid gear approach improves long‑term stability for miniature robotics systems, enabling consistent performance across different operating conditions without significantly increasing servo weight or size.
Integrated Protection and Real‑Time Feedback
Built‑in safety and monitoring functions enhance operational reliability in complex motion systems. Wide voltage protection automatically stops rotation when supply voltage rises too high or drops below safe levels, protecting internal electronics. Additional safeguards trigger self‑unloading force protection when overheating, overcurrent, overvoltage, or overload conditions occur. Real‑time parameter feedback provides status data including temperature, speed, voltage, load, and position, enabling closed‑loop monitoring and intelligent diagnostics during robotic system operation.
Dual Operating Modes for Robotics Applications
This programmable miniature actuator supports both angle‑controlled servo mode and continuous rotation wheel mode. Position mode enables accurate angular control within the 180° mechanical range, ideal for robotic joints and articulated mechanisms. Wheel mode allows cyclic rotation for drive systems and mobile robotics. Combined with programmable limits and fast serial communication control, this intelligent motion component adapts easily to robotics experimentation, automation prototypes, and STEM Education platforms requiring flexible motion behavior.
Compact size, configurable communication control, and integrated protection features make this miniature serial bus actuator suitable for robotics education, UAV mechanisms, experimental automation devices, and security equipment requiring coordinated multi‑servo movement in constrained spaces.
Figure: Included servo horns and accessories
