Terminal Block Shield for Arduino Mega
$36.90
SKU: DFR0921
  • $36.00 3+ items
  • $35.00 5+ items
  • $34.00 10+ items
A terminal block shield ensures stable connections by securing loose wires. It supports 3.3V, 5V, and GND ports and operates on 7-24V without extra circuits.
Purchase this product and earn 369 reward points, which are tied to VIP membership program. Learn More >
Has it ever happened to you that you spent a lot of time ascertaining a problem when making projects and finally found out it was just caused by loose wiring? Then, what you may need is a terminal block shield like this!
The shield adopts terminal blocks to secure wires so as to make connections stable and reliable. And multiple 3.3V, 5V, and GND ports are provided for easy wiring. It can be powered by 7~24V voltage without an additional buck-down circuit. The onboard 18pin-FPC socket makes it convenient for connecting a screen.
Application
Terminal Block Shield for Arduino Mega Due
Board Overview
GDI 18pin-FPC
FPC PINS Mega PINS Description
VCC 5V 5V
BLK D7 Backlight
GND GND GND
SCLK D52 SPI clock
MOSI D51 Host output, slave input
MISO D50 Host input, slave output
DC D2 Data/command
RES D4 Reset
CS D3 TFT Chip Select
SDCS D6 SD card Chip Select
FCS D25 Font library Chip Select
TCS D5 Touch Chip Select
SCL SCL I2C clock
SDA SDA I2C data
INT D19 INT
BUSY-TE D24 ripstop pins
X1 D23 custom pin 1
X2 D22 custom pin 2
  • Stable and reliable connection
  • Easy wiring
  • Commercial Project
  • Art Show
  • VIN Input Voltage: 7-24V DC
  • Max Load Power: 10W
  • Terminal Block Pitch: 3.5mm
  • Cable Size Range: 26AWG-16AWG
  • Wire Strip Length: 5mm
  • Screw: M2
  • Dimension: 101.5 *53.3 mm/4.00*2.10”
  • Terminal Block Shield for Arduino Mega x1
    Only 1 Left
