GM73 Barcode & QR Code Scanning Module
$38.90
SKU: SEN0544
High-speed scanner captures 1D/2D codes in 1s, with smart image recognition and easy setup. Features USB/UART, ideal for vending machines and access control.
Purchase this product and earn 389 reward points, which are tied to VIP membership program. Learn More >
The GM73 code reader module is a high-performance scanner that captures common 1D and 2D codes—like barcodes and QR codes on labels, paper, or screens—with a high speed of about 1 second.
The module delivers superior reading performance by utilizing advanced decoding algorithms based on smart image recognition, allowing it to read all kinds of codes accurately. Users can configure parameters by simply scanning setup codes, which greatly reduces development difficulty. With onboard micro USB and UART, it can be conveniently embedded into various devices.
Version Update (21/7/2025)
This new version of the GM73 module has been significantly upgraded for enhanced performance, security, and flexibility.
  • Enhanced Security: Settings can now be password-protected to prevent unauthorized changes.
  • Superior Light Tolerance: Adapts to a much wider range of lighting conditions, now supporting 0 to 100,000 Lux.
  • Advanced Scanning & Data Control: Introduces Host-controlled scanning mode, advanced data editing like character substitution, and flexible configuration for UPC/EAN add-on codes.
  • Smarter Recognition: Automatically detects and decodes mirrored barcodes without manual setup. It also now supports auto-recognition for Chinese VAT invoices.
  • Expanded Compatibility: Offers broader multi-language keyboard layouts (including Chinese) and supports Unicode output for more versatile data encoding.
  • Features
  • Smart image recognition
  • Fast capture speed of about 1s
  • Onboard micro USB and UART for easy integration
  • Multiple scanning modes: Manual / Continuous / Sensing / Host Mode
  • Password-protected configuration settings
  • Excellent light tolerance for various environments
  • Advanced data editing and flexible add-on code configuration
  • Multi-language keyboard support
  • Self-service vending machines
  • Metro gates
  • Access control systems
  • Checkout counters
  • Image Sensor: 640×480 CMOS
  • Decoding Speed: ≤1 second
  • Read Precision (Minimum Bar Width): 6 mil (0.15mm)
  • Print Contrast: ≥25% (ISO/IEC 15416 compliant)
  • Scanning Modes: Manual / Continuous / Sensing / Host Mode
  • Data Editing: Prefix / Suffix / CodeID / Substitution
  • Security: Password-protected settings (default: 0x86)
  • 1D Barcodes: EAN/UPC, Code 39/93/128, Codabar, etc.
  • 2D Codes: QR, Data Matrix, PDF417, Aztec, Hanxin
  • Reading Distance:
            30-150mm (high contrast)
            50-120mm (low contrast/screens)
  • Scanning Angles:
            360° horizontal
            ±55° pitch/skew
  • Field of View: 60°(H)×46°(V)
  • Interfaces: TTL-232 (RS232 compatible), USB 2.0 (Micro-B)
  • Power: ≤100mA @5V DC
  • Light Tolerance: 0 - 100,000 Lux
  • Data Encoding: GBK / UTF-8 / Unicode
  • Keyboard Layouts: Multi-language (including Chinese)
  • Temperature:
            Operation: -20°C to +50°C
            Storage: -40°C to +70°C
  • Humidity: 5-95% non-condensing
  • GM73 Barcode & QR Code Scanning Module x1
  • USB Cable x1
  • TTL Adapter x1
  • Only 11 Left
