Gravity: AHT20 Temperature and Humidity Sensor
$3.90
SKU: SEN0528
High-precision, low-cost temperature and humidity sensor with I2C interface, operates at 2V-5V, suitable for various applications like HVAC and automobiles.
The AHT20 is a high-precision but low-cost temperature and humidity sensor, which is equipped with an improved MEMS semiconductor capacitive humidity sensor element. It features standard I2C interface and a wide voltage supply of 2V-5V. And with the simple peripheral circuit, it performs stably even in harsh environments in the measuring range of -40℃ ~ +85℃.
This sensor can be widely used for measuring the environmental temperature and humidity of home electronic equipment, the temperature and humidity of automobiles, and so on.
Connection Diagram
  • Digital output, I2C interface
  • Excellent long-term stability
  • Fast response, strong anti-interference, and adaptability
  • Gravity interface, simple wiring, no soldering required
  • HVAC
  • Dehumidifier
  • Testing Equipment
  • Consumer Appliances
  • Automobiles
  • Automatic Control
  • Data Loggers
  • Weather Control
    Module Parameters
  • Operating Voltage: DC2V-5V
  • Output Signal: I2C
  • I2C Address: 0x38
  • Dimension: 30mm×20.5mm/1.18×0.81"
  • AHT20 Chip Parameters
    Relative Humidity
  • Resolution: 0.024 %RH
  • Accuracy Error: ±2 %RH
  • Repeatability: ±0.1 %RH
  • Hysteresis: ±1 %RH
  • Non-linear: ±0.1 %RH
  • Response Time: 8S
  • Operating Range: 0~100 %RH
  • Long-term Drift: <0.5 %RH/yr
  • Temperature
  • Resolution: 0.01℃
  • Accuracy Error: ±0.3℃
  • Repeatability: ±0.1℃
  • Hysteresis: ±0.1℃
  • Response Time: minimum 5S, maximum 30S
  • Operating Range: -40℃~85℃
  • Long-term Drift: <0.04℃/yr
  • Gravity: AHT20 Temperature and Humidity Sensor × 1
  • Gravity-4P I2C/UART Sensor Cable × 1
    Smart Solar Plant(Environment monitoring)
    Projects Smart Solar Plant(Environment monitoring)
    RAJESHKT
    May 17, 2024
