DTOF STL-19P Laser LiDAR Sensor Kit (12m)
$119.00
SKU: SEN0547
  • $116.00 3+ items
  • $114.00 5+ items
  • $110.00 10+ items
Compact LiDAR sensor with a 12m range and 360° scanning for mapping and obstacle detection. Works with ROS systems, ideal for drones and smart devices.
Purchase this product and earn 1190 reward points, which are tied to VIP membership program. Learn More >
STL-19P LiDAR Sensor Kit
This STL-19P LiDAR sensor offers a ranging distance of up to 12m and 360° environmental scanning, which can realize autonomous mapping, and obstacle detection.
The sensor is compact and light, and its size nearly equals to a ping-pong ball and the weight nearly to 2 AA dry batteries.
DSTL-19P LiDAR Sensor Kit
Also, it can resist the strong light of 60 Klux, which achieves high-precision distance measurement indoors and outdoors.
The provided SDK works well with both ROS1 and ROS2 systems.
And the adopted brushless motor boasts long-lasting operation with high-speed data transmission.
Laser SafetyFDA Class I
Comparison of STL-19P and LD19 Technical Specification
  • Distance measurement up to 12m radius
  • Compact and stylish
  • Anti-Strong Light Interference
  • Long Lasting
  • Home Service Robot
  • Commercial Service Robot
  • Special robot
  • Drone
  • Industrial robot
  • STL-19P LiDAR Applications
  • Model: LD19
  • Ranging Distance: 0.02m~12m (target reflectivity of 70%)
  • Ranging Frequency: 4500Hz
  • Scanning Frequency: 10Hz(Typical)
  • Ranging Average Accuracy: ±45mm (0.3m~12m)
  • Ranging Standard Deviation: 10mm (0.3m~12m)
  • Measurement Resolution: 15mm
  • Scanning Range: 360°
  • Angle Error: ±2°
  • Angle Resolution: 0.8°@10Hz
  • Ambient Light Resistance: 30KLux
  • Laser Wavelength: 895~915nm(Typical 905nm)
  • Pitch Angle: 0-2°
  • Input Voltage: 5V
  • Operating Current: 180mA
  • Product Power: 0.9W
  • Dimensions: 38.59*38.89*33.50mm/1.52*1.53*1.32” (L*W*H)
  • Weight: 47g
  • Baud Rate: 230400
  • Communication Interface: UART (3.3V level)
  • Operating Temperature: -10℃~40℃
  • Storage Temperature: -30℃~70℃
  • Motor: Brushless Motor
  • STL-19P LiDAR Sensor ×1
  • Adapter Board ×1
  • 4PIN Cable ×1
  • USB Cable(Random Colors) ×1
    7 Real-World Applications of LiDAR Technology
    Blog 7 Real-World Applications of LiDAR Technology
    Apr 11, 2023
    Only 16 Left
