Titan Case for LattePanda 3 Delta (NOT Compatible with LattePanda V1 & LattePanda 2 Alpha&Delta)
$19.00
SKU: FIT0906
  • $18.50 3+ items
  • $18.00 5+ items
  • $17.50 10+ items
The titan case features a sci-fi design, offers protection for components, is easy to assemble, and provides access to all ports of LattePanda 3 Delta.
Purchase this product and earn 19 reward points, which are tied to VIP membership program. Learn More >
Note: This titan case is only compatible with LattePanda 3 Delta 864.
Dedicated Design, Superior Texture
Titan case uses conflict aesthetics to combine functional design considerations with sci-fi elements. Understated color selection and layered surface treatment technology create a kind of design, flat but with unlimited potential.
Two Models, Balancing Extensibility And Integrity
Invisible quick-release cover design. A complete computer after fastening, or an open hardware development platform after quick disassembling.
Perfect Protection
High-strength engineering plastic effectively protects the internal precise electronic components from accidental falls and static damage in a complex development environment.
Note: Use M4 screws for the two middle holes in the bottom case, and make sure to control their length to avoid using screws that are too long, as they could damage the PCB when fully tightened. The maximum length for screwing from the outside of the shell to the inside is 7mm; screws that are 9mm long will touch the PCB. If you're mounting the case onto a device with a thickness of 'a' mm, the maximum screw length you should use is (a+7) mm.
  • Protect components
  • Fast and easy to assemble
  • Easy access to all ports and slots of LattePanda 3 Delta
  • LattePanda 3 Delta
  • Compatible Model: LattePanda 3 Delta
  • Material: ABS+PC
  • Dimensions: 130*87*32 mm / 5.12*3.07*1.26 inch
  • Weight: 110g
  • Titan case x1
  • M3 screws x6
  • FAQ
    Sean.Farmar Mar 15, 2026
    Excellent product, very useful for running home projects
    Jan.Holtzhausen Feb 23, 2026
    Can't imagine having a LattePanda without this perfect case...
    Guadalupe.Flores Feb 10, 2026
    Perfect case for the board.
