Gravity: I2C 4-20mA DAC Module (Arduino Compatible)
$9.90
SKU: DFR0972
  • $9.70 3+ items
  • $9.50 5+ items
  • $9.20 10+ items
An I2C DAC module outputs 0-25mA current, with accurate 4-20mA after calibration, compatible with Arduino, and useful for devices like motors and pumps.
This is an I2C DAC module that outputs 0–25mA current. It provides accurate 4–20mA current output after calibration, making it suitable for controlling industrial devices such as motors, inverters, valves, and pumps via Arduino or other microcontrollers.
Designed to convert digital signals into standard 4–20mA industrial control signals, this module serves as a bridge between microcontroller platforms and industrial systems.
With I2C communication and provided sample code, users can easily control the output current by setting digital values, enabling quick integration into automation and control projects.
This DAC module requires an external 18–24V power supply for proper 4–20mA loop operation.
I2C 4-20mA DAC module
Function Indication
Hardware Connection
Click here to get Selection Guide of DAC Modules
Selection Guide
DFRobot Gravity DAC Module Selection Guide
Figure
SKU
DFR0552
DFR0971
DFR0972
DFR1071
DFR1036
DFR1037
DFR1073
DFR1035
DFR1230
DFR1034
DFR1229
Add to Cart
Description
I2C 12-Bit DAC
2-Ch 0-10V DAC
4-20mA Current DAC
1-Ch 15-Bit (0-10V)
1-Ch PWM (0-10V)
2-Ch PWM (0-2.5V)
2-Ch 15-Bit (0-10V)
1-Ch 15-Bit (0-2.5V)
Hi-Res ±10V / 4-20mA
2-Ch 12-Bit (0-2.5V)
Hi-Res 0-10V / 4-20mA
Comm.
I2C
I2C
I2C
I2C
PWM
PWM
I2C
I2C
I2C/PWM
I2C
I2C/PWM
Res.
12-bit
12-bit
12-bit
15-bit
8-bit
8-bit
15-bit
15-bit
16-bit
12-bit
16-bit
Channels
1
2
1
1
1
2
2
1
1
2
1
Output Range
0~VCC
0-10V / 0-5V
4-20mA (0-25mA)
0-10V / 0-5V
0-10V / 0-5V
0-2.5V / 0-VCC
0-10V / 0-5V
0-2.5V / 0-VCC
±10V, 0-10V, 4-20mA
0-2.5V / 0-VCC
0-10V, 0-10V, 4-20mA
Chip
MCP4725
GP8403
GP8302
GP8211S
GP8101S
GP8501
GP8413
GP8512
GP8630N
GP8503
GP8600
Key Features
Classic model, with EEPROM, cost-effective
Dual-channel industrial voltage, cascade up to 16 devices
Industrial current loop, requires 18-24V power
High precision (0.01%), single channel
PWM driven, easy to use, industrial voltage
PWM driven, dual channel, low voltage control
High precision, dual channel, industrial voltage
High precision, single channel, low voltage control
Flagship, supports bipolar (negative voltage) output
Medium precision, dual channel, low voltage control
16-bit ultra-high precision, multi-function all-in-one
  • 0-25mA output, more accurate current within 4-20mA available after calibration
  • Gravity interface, I2C communication
  • High accuracy, 0.2% linearity error
  • 18-24V power supply
  • Function signal generator
  • Automatic controller for lighting or fountain
  • Automatic and quick transformation of small equipment
  • Electromechanical equipment debugging
  • Transformation of small test device
  • Chip Type: GP8302
  • Input Signal Range: 12Bit, 0x000-0xFFF (0-25mA)
  • Input I2C Signal High Level: 2.7V-5V
  • Power Supply: 18V-24V (24V recommended)
  • Accuracy: 0.5% before calibration, 0.2% after calibration
  • Power Consumption: <5mA
  • Start-up Time: <2ms
  • Operating Temperature: -40°C to 125°C
  • Load Resistance: Maximum 450Ω load capacity for 18V power supply, maximum 750Ω for 24V
  • Output Current: 0-25mA
  • I2C Address: 0x58
  • Gravity: I2C 4-20mA DAC Module (Arduino Compatible) x1
  • Gravity I2C/UART Sensor Connector x1
    Certifications
    Blog Selection Guide of DAC Modules
    Oct 25, 2023
    Gareth.Carr Feb 13, 2026
    Works great giving accurate readings
    LARRY.SCHRIMPF Oct 12, 2023
    Extremely accurate when used with calibration. Recommended for any 4-20mA output needs.
