Fermion: I2S MEMS Microphone (Breakout)
$4.90
SKU: SEN0526
  • $4.80 3+ items
  • $4.70 5+ items
  • $4.50 10+ items
Compact digital I2S MEMS microphone for microcontrollers, featuring low noise and high sensitivity. Ideal for voice recognition, AI learning, and Bluetooth audio.
This digital I2S MEMS Microphone works well with microcontrollers with I2S audio outputs like ESP32. Compared with traditional analog ones, this microphone features low noise, high sensitivity & reliability, and other excellent performances, which make it applicable to projects like voice recognition, recording, AI learning, Bluetooth audio transmission, and so on.
This module uses surface mount MEMS I2S microphone sensor with top port, no components at the bottom, which can be embedded into various applications conveniently. Besides, DFRobot provides users with Arduino library for this product to allow them easily get started on ESP32.
Connection Diagram
  • Small in size
  • Low power consumption & high performance
  • I2S digital output with low noise
  • MEMS sensor with high reliability
  • Provides Arduino library for working on ESP32
  • Voice recognition
  • AI learning
  • Recording
  • Bluetooth audio transmission
  • Smart home audio projects
  • Operating Voltage: DC 3.3V
  • Microphone Packaging Process: MEMS
  • Direction: Omnidirectional
  • Data Port: I2S
  • Sound Pressure Level: 140dB
  • Signal-to-noise Ratio: 59dB
  • Dimension: 11mm×16mm/0.43×0.63"
  • Fermion: I2S MEMS Microphone ×1
  • 6P Black Single-row Pin Connector ×1
    AI-driven Sound and Thermal Image-based HVAC Fault Diagnosis
    Projects AI-driven Sound and Thermal Image-based HVAC Fault Diagnosis
    Kutluhan Aktar
    Aug 09, 2024
    Multi-Model AI-Based Mechanical Anomaly Detector w/ BLE
    Projects Multi-Model AI-Based Mechanical Anomaly Detector w/ BLE
    Kutluhan Aktar
    Feb 09, 2024
    Dillon.Simeone Jul 01, 2025
    The form factor... Oh man. You can just add pins, then drop them right onto most ESP32s from one of the corners. All of the pins will line up perfectly! No need for a PCB boardbreakout when you're doing this. Very durable.
    Julian.van Hemert Feb 17, 2025
    I haven't yet tested it, but it came well packaged and in good condition.
    Goran.Perovic Jan 06, 2025
    Fermion: I2S MEMS Microphone (Breakout) Easy to use with any Esp32. Thank you DF.
    Out Of Stock
