DC Water Pump (DC2.1 Connector)
$2.50
SKU: FIT0910
  • $2.40 3+ items
  • $2.30 5+ items
  • $2.20 10+ items
A DC water pump for fountains, aquariums, and plant-watering projects. Features easy setup, 1m wire, and operates at 3-6V. Ideal for beginners.
Make small fountains, auto aquarium water changers, or plant-watering projects with this water pump!
This DC water pump inherits all benefits from the previous Amphibious Horizontal Submersible Pump, and comes with an improved DC2.1 connector and longer wire(1m), which can be used in deep water scenarios. It’s great for beginner projects and super easy to use!
Hardware Connection
Note: It is recommended to use with Easy Relay Module.
  • DC2.1 connector, plug and go
  • 1m wire for more applications
  • 3-6V operating voltage, safe for education scenarios
  • Fountain
  • Aquarium water changer
  • DIY plant watering
  • Agricultural Irrigation
  • Power Supply: DC 3 to 6V
  • Current: 150 to 370mA
  • Lift: 25 to 45cm
  • Flow: 80-100L/H
  • Power: 0.4 to 2W
  • Water Inlet/Outlet: 5mm/0.20”
  • Wire Length: 1m
  • DC Water Pump (DC2.1 Connector) x1
  • Pipe 1m x1
    Niu.yx
    Feb 11, 2025
