Make small fountains, auto aquarium water changers, or plant-watering projects with this water pump!
This DC water pump inherits all benefits from the previous Amphibious Horizontal Submersible Pump, and comes with an improved DC2.1 connector and longer wire(1m), which can be used in deep water scenarios. It’s great for beginner projects and super easy to use!
Hardware Connection
Note: It is recommended to use with Easy Relay Module.
