CS20 Depth-Only ToF 3D Camera for ROS (640x480, 5m, 60°x45° FOV)
$160.00
SKU: SEN0579
A compact 3D TOF LiDAR with 640x480 resolution, measuring distances up to 5m with 1.2W power. Compatible with Linux, Windows, ROS, Android. Ideal for 3D applications.
Purchase this product and earn 1600 reward points, which are tied to VIP membership program. Learn More >
This CS20 Dual-Resolution 3D TOF Solid-state LiDAR is equipped with a ToF image sensor with a resolution of 640*480 and uses ToF technology to capture three-dimensional information of objects and space. It can accurately measure distances up to 5m while consuming an average of only 1.2W of power. This makes it a convenient and efficient tool for 3D perception applications.
The LiDAR is compact and lightweight and compatible with multiple operating systems, including Linux, Windows, ROS, and Android. It is powered and outputs phase information through a Type C interface. And users can obtain depth, point clouds, and other data via the SDK. It is widely used in various applications such as robot SLAM, volume measurement, face recognition, somatosensory interaction, 3D modeling, security monitoring, and people counting.
Compared to 3D structured-light cameras, ToF depth cameras offer several advantages, such as a small blind spot, linearly related measurement errors that are not affected by distance or scene texture, fast imaging speed, and strong environmental adaptability. Many commercially available ToF depth cameras are currently afflicted by relatively high costs and limited depth resolution, which can lead to less precise depth information capture. But this cost-effective camera sensor not only has excellent 3D imaging capabilities but also achieves millimeter-level measurement accuracy.
Working Principles:
A Brief Analysis of the Principles of Depth Cameras: Structured Light, TOF, and Stereo Vision
How it works - Dual-Resolution 3D ToF Depth Camera Sensor
Figure: How does the Dual-Resolution 3D ToF LiDAR work
Design of Dual-Resolution 3D ToF Depth Camera Sensor
Figure: Design of Dual-Resolution 3D ToF LiDAR
Overview of Dual-Resolution 3D ToF Depth Camera Sensor
Figure: Overview of Dual-Resolution 3D ToF LiDAR
Tested 3D Point Cloud Effect
3D Point Cloud Images for Resolution Comparison
Figure: 3D Point Cloud Images for Resolution Comparison
Close-up View of 3D Point Cloud Image (640*480)
Figure: Close-up View of 3D Point Cloud Image (640*480)
3D Point Cloud Image in Dark Environment (Drawer)
Figure: 3D Point Cloud Image in Dark Environment (Drawer)
What are the differences between 3D ToF cameras and the previous ordinary cameras (2D)?
3D ToF camera can detect the depth of field distance of space. This means that it can provide accurate data on the distance of each point in the image from the camera. In contrast, an ordinary 2D camera can only capture and record objects within its view but does not include information about their distances from the camera. With a 3D ToF camera, the real scene can be restored through three-dimensional coordinates, and applications such as scene modeling can be realized.
Selection Guide
Depth Sensing Camera Selection Guide
Figure
SKU
SEN0581
SEN0583
SEN0579
SEN0673
Depth Resolution
100×100 @ 20fps
320×240
640×480 / 320×240
640×480 / 320×240
Sensing Range
0.15 – 1.5m
0.2 – 2m (indoor)
0.1 – 5m (90% reflectivity)
0.1 – 5m
RGB Support
No
Yes
No
Yes
RGB Resolution
N/A
800×600
N/A
1920×1080 / 640×480
Measurement Accuracy
≤1% / cm
≤1% / cm
±1.5cm @ 0.5m ±1% @ 0.5–5m
±2.5cm @ 0.5m ±1% @ 0.5–5m
FOV (Depth)
H70° × V60°
H55° × V72°
H60° × V45°
H97° × V95.5°
FOV (RGB)
N/A
H78° × V98°
N/A
H91.5° × V59°
Power Consumption
Low (5V supply)
Medium (with active cooling)
Avg. 1.2W (5V / 0.5A)
Avg. 3W (5V / 0.6A)
Data Interface
UART / USB 2.0
UART / USB 2.0
USB 2.0 Type-C
USB 3.0 Type-C
Compatibility
Windows / Linux / ROS
Linux (RNDIS)
Win10 / Linux / ROS
Win10 / Ubuntu / ROS
Special Features
Built-in LCD for real-time preview
RGB-3D fusion Python SDK
Dual-frequency / single-frequency modes Industrial-grade reliability
AI recognition Wide dynamic range
Laser Safety
N/A
N/A
Class 1
Class 1
Add to Cart
  • Millimeter-level measurement accuracy
  • Typical measurement range: 0.1- 5m@indoor white wall
  • Resolution: 640*480
  • High dynamic measurement range
  • Supports depth and signal amplitude timing synchronization
  • Adjustable range and frame rate
  • Robot SLAM
  • Volume measurement
  • Face recognition
  • Somatosensory interaction
  • 3D modeling
  • Security monitoring/People counting
  • Model: CS20
  • Depth Resolution: 640×480/320×240
  • Range Ability: 0.1-5m, indoor
  • VCSEL Wavelength: 940nm
  • Accuracy: 1% @white wall
  • FOV: H60° × V45° (Receiver)
  • Size: 48mm × 34mm × 12mm/1.89×1.34×0.47"
  • Data Transmission: USB 2.0, Type C Interface
  • Power Supply: 5V, 0.5A
  • Power Dissipation: 1.2W
  • Operating System: Linux/Windows/ROS/Android
  • Operating Temperature: -10 to 50℃
  • Security: Class 1
  • CS20 Dual-Resolution 3D TOF Solid-state LiDAR (5m)× 1
    Certifications
    Exploring the Differences: Solid-State LiDAR vs Mechanical LiDAR
    Blog Exploring the Differences: Solid-State LiDAR vs Mechanical LiDAR
    Sep 13, 2023
    Only 16 Left
