Fermion: Formaldehyde Sensor (Breakout, 0-3ppm MEMS HCHO Detection, Low Power)
$4.90
SKU: SEN0563
  • $4.80 3+ items
  • $4.70 5+ items
  • $4.60 10+ items
Compact MEMS sensor detects formaldehyde gas with low power, high sensitivity, and quick response, suitable for air purifiers, HVAC, and wearables.
Ensure safe indoor air quality with the Fermion MEMS Formaldehyde Sensor (HCHO), a high-sensitivity detector for 0-3ppm gas concentrations. Perfect for HVAC systems, air purifiers, and portable monitors, this low-power sensor delivers fast, reliable results with MEMS technology.
High Sensitivity & Fast Response
The MEMS-based sensor detects HCHO concentrations (0-3ppm) with rapid recovery times, ensuring real-time monitoring for health-critical environments.
Ultra-Low Power Consumption (<20mA)
Designed for battery-operated devices, the sensor’s minimal power draw extends operational life in portable detectors and IoT deployments.
Compact & Easy to Integrate
At just 13×13×2.5mm, the sensor fits seamlessly into air purifiers, smart wearables, and Arduino/Raspberry Pi projects with analog voltage output.
Durable for Long-Term Use
With a 3-year lifespan and -10°C to 50°C operating range, it withstands diverse environments while avoiding interference from humidity or contaminants.
Precautions for use
  • Features
  • Low power consumption,operating current <20mA
  • Advanced MEMS technology
  • Air purifiers
  • HVAC systems
  • Smart wearables
  • Portable detectors
  • Gas detected: Formaldehyde (HCHO)
  • Detection range: 0-3ppm
  • Operating voltage: 3.3-5V
  • Operating current: <20mA
  • Sensitivity: R0(in air)/Rs(in 0.4ppm HCHO) ≥ 1.8
  • Lifespan: ≥3 years (in air)
  • Dimension:13×13 x 2.5mm/ 0.0.51×0.51x0.1"
  • Fermion: MEMS Formaldehyde HCHO Gas Detection Sensor (breakout) × 1
  • 2.54mm pitch header pin × 1
    Jul 27, 2023
