Fermion: H2S Gas Sensor – Hydrogen Sulfide Detector (Breakout, 0.5-50ppm, MEMS, Low Power)
$7.50
SKU: SEN0568
  • $7.20 3+ items
  • $7.10 5+ items
  • $6.90 10+ items
Compact MEMS sensor for detecting hydrogen sulfide, ideal for use in toilets and sewers. Features low power consumption, quick response, and qualitative measurement.
Protect against toxic hydrogen sulfide (H2S) exposure with the Fermion MEMS H2S Sensor, a high-sensitivity detector for 0.5-50ppm gas concentrations. Designed for sewers, waste treatment, and industrial safety, this low-power sensor delivers fast, accurate results with MEMS technology.
Accurate H2S Detection (0.5-50ppm)
The MEMS-based hydrogen sulfide sensor detects low to high concentrations with high sensitivity, ensuring reliable safety monitoring in hazardous environments.
Ultra-Low Power (<20mA) & Compact
At just 13×13×2.5mm, this energy-efficient sensor integrates seamlessly into portable detectors and IoT safety systems.
Fast Response & Long Lifespan (≥5 Years)
With minimal preheating time and durable construction, the sensor is ideal for continuous monitoring in high-humidity or corrosive environments.
Please note: This sensor is capable of qualitative measurements only. For quantitative measurements, kindly consider purchasing the Gravity: Factory Calibrated Electrochemical Gas Sensor Series.
Precautions for use
  • Features
  • Low power consumption, operating current <20mA
  • Advanced MEMS technology
  • Hydrogen sulfide detection in toilets, sewers, garbage stations
  • Gas detected: Hydrogen Sulfide (H2S), Benzene
  • Detection range: 0.5-50ppm
  • Operating voltage: 3.3-5V
  • Operating current: <20mA
  • Sensitivity: R0 (in air)/Rs (in 50ppm H2S) ≥ 3
  • Lifespan: ≥5 years (in air)
  • Dimension: 13×13 x 2.5mm/0.0.51×0.51x0.1”
  • Fermion: MEMS H2S Sensor (breakout) × 1
  • 2.54mm pitch header pin × 1
    Certifications
    Jul 27, 2023
