Prevent toxic ammonia (NH3) exposure with the Fermion MEMS NH3 Sensor, a high-sensitivity detector for 1-300ppm gas concentrations. Designed for cold storage, aquaculture, and industrial safety, this low-power sensor delivers fast, accurate results with MEMS technology.
Accurate NH3 Detection (1-300ppm)
The MEMS-based ammonia sensor detects low to high concentrations with high sensitivity, ensuring reliable safety monitoring in hazardous environments.
Ultra-Low Power (<20mA) & Compact
At just 13×13×2.5mm, this energy-efficient sensor integrates seamlessly into portable detectors and IoT safety systems.
Fast Response & Long Lifespan (≥5 Years)
With minimal preheating time and durable construction, the sensor is ideal for continuous monitoring in high-humidity or corrosive environments.
Please note: This sensor is capable of qualitative measurements only. For quantitative measurements, kindly consider purchasing the Gravity: NH3 Sensor (Calibrated).
Precautions for use
