Fermion: MEMS Methane CH4 Gas Detection Sensor (Breakout, 1-10000ppm)
$4.90
SKU: SEN0565
  • $4.80 3+ items
  • $4.70 5+ items
  • $4.60 10+ items
Compact MEMS sensor detects methane gas, offers low power use, swift response, and qualitative measurements for safety monitoring. Suitable for various applications.
Fermion: MEMS Methane CH4 Gas Detection Sensor employs state-of-the-art micro-electromechanical system (MEMS) technology, endowing the sensor with compact dimensions (13x13x2.5mm), low power consumption (<20mA), minimal heat generation, short preheating time, and swift response recovery. The sensor can qualitatively measure methane gas concentration and is suitable for combustible gas leakage monitoring devices, gas leak detectors, fire/safety detection systems and other applications.
Please note: This sensor is capable of only qualitative measurements. For quantitative measurements, kindly consider purchasing the Gravity: Factory Calibrated Electrochemical Gas Sensor Series.
Wiring Diagram of Fermion: MEMS CH4 Gas Sensor and Arduino UNO
Figure: Wiring Diagram of Fermion: MEMS CH4 Gas Sensor and Arduino UNO
Precautions for use
  • Features
  • Low power consumption, operating current <20mA
  • Advanced MEMS technology
  • Environmental monitoring: detect the presence of methane emissions or leaks from natural or anthropogenic sources.
  • Indoor air quality: measure the concentration of methane in the indoor air and control the ventilation or alarm systems accordingly.
  • Industrial safety: detect any leaks or spills of methane and warn the workers or the managers to take preventive measures.
  • Fire detection: identify any abnormal increase of methane in the air and trigger the fire alarm or sprinkler system.
  • Health applications: measure the amount of methane in the breath, methane can be produced by some bacteria in the human gut or some metabolic disorders
  • Gas detected: CH4, C3H8, etc
  • Detection range: 1-10000ppm (C3H8)
  • Operating voltage: 5V
  • Operating current: <20mA
  • Sensitivity: R0(in air)/Rs(in 5000ppm CH4) ≥ 2
  • Lifespan: ≥5 years (in air)
  • Dimension:13×13 x 2.5mm/0.0.51×0.51x0.1"
  • Fermion: MEMS CH4 Sensor (breakout) × 1
  • 2.54mm pitch header pin × 1
    Certifications
    Hydroponics Simulation Model
    Projects Hydroponics Simulation Model
    RosarIoT
    Dec 22, 2021
    Jul 27, 2023
    No-Code Gas Detector Prototype
    Projects No-Code Gas Detector Prototype
    RosarIoT
    Aug 09, 2024
    Smoke and methane detection with FireBeetle 2 ESP32-C6 and Alvik robot
    Projects Smoke and methane detection with FireBeetle 2 ESP32-C6 and Alvik robot
    RoniBandini
    Aug 05, 2024
    Alan .Arias Diosdado Oct 29, 2025
    Tal como se describe en la página. Excelente producto
