This advanced MEMS ethanol sensor provides reliable qualitative detection of alcohol vapors (1-500ppm), perfect for breathalyzer development and industrial safety applications.
Ultra-Compact Design
At just 13×13×2.5mm, this micro sensor fits seamlessly into portable devices and wearables while consuming <20mA power - ideal for battery-powered applications.
Fast Response Technology
MEMS construction enables rapid detection with minimal preheating time, delivering immediate vapor concentration alerts when alcohol is present.
Multi-Purpose Detection
Sensitive to both ethanol (EtOH) and volatile organic compounds (VOCs), making it versatile for breath analysis, food quality monitoring, and industrial safety systems.
Simple Integration
Standard 3.3-5V operation with analog output connects effortlessly to Arduino and other microcontrollers via the included breakout board.
Long Operational Life
Robust MEMS technology ensures ≥5 years of continuous service in normal conditions when properly maintained.
Please note: This sensor is capable of only qualitative measurements. For quantitative measurements, kindly consider purchasing the Gravity: Factory Calibrated Electrochemical Gas Sensor Series.
Figure: Wiring Diagram of Fermion: MEMS EtOH Sensor and Arduino UNO
Precautions for use
